![]() | Home > Technical (L322) > Gear selection noise |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
Hi,
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Thanks for the contribution matey.. you are spot on. Looks like that's my issue not the gearbox. |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
It's possible that the universal joint on the rear propshaft is worn/damaged. I had the same problem with my TD6, discussed in my recent post on a rumbling noise under hard acceleration, The clunk I got was due to the universal joint giving slightly when engaging reverse gear. |
I will have a wee read of your post shortly. Is it a big repair? Probably one job I will pass over to my mechanic mate tbh.. love working on the car but after doing some research on this I'm out my depth.. 👍 |
Replacing the propshaft is not a big job, takes about an hour tops to do. If you can't stomach the cost of a new shaft with centre bearing (about £800 for a genuine LR shaft |
