Home > Technical (L322) > Gear selection noise
alistairh
This seems to be getting worse on the car.. when I select either drive or reverse I get a "thump" I've noticed if I'm gentle with the selector it's not as apparent? I'm servicing the gearbox next week so hoping the new oil may help. Cars also a bit hesitant when you select drive and don't touch accelator it's very slow at moving off.. if I touch the pedal it flys so no issues in it selecting the gear just very slow to move.. in reverse it still moves quickly without touching pedal..??
Post #434964 15th Apr 2017 8:17am
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Hi,
The thump may not be gearbox related - Last year my FF developed a 'thump' when selecting reverse , being a TD6 with it's super strong gearbox lol, I thought it was the gearbox showing it age !! Turned out it was a rear CV joint (it broke a few months later) The thump noise was travelling up the prop shaft into the gearbox area.
Whilst you are underneath get a friend to select reverse and see if there is any movement in the rear driveshafts - Just make sure it's a good friend who will keep the brakes on as you lie next to the rear wheels !! Rolling with laughter
Simon
Post #434980 15th Apr 2017 1:00pm
alistairh
Thanks for the contribution matey.. you are spot on. Looks like that's my issue not the gearbox. Thumbs Up
Post #434984 15th Apr 2017 3:30pm
Discotigger
It's possible that the universal joint on the rear propshaft is worn/damaged. I had the same problem with my TD6, discussed in my recent post on a rumbling noise under hard acceleration, The clunk I got was due to the universal joint giving slightly when engaging reverse gear.
Post #434989 15th Apr 2017 5:39pm
alistairh
I will have a wee read of your post shortly. Is it a big repair? Probably one job I will pass over to my mechanic mate tbh.. love working on the car but after doing some research on this I'm out my depth.. 👍
Post #434990 15th Apr 2017 6:48pm
Discotigger
Replacing the propshaft is not a big job, takes about an hour tops to do. If you can't stomach the cost of a new shaft with centre bearing (about £800 for a genuine LR shaft Shocked ) there are plenty of good second hand ones to be had. I got a really good 2nd hand shaft from ebay for £90 from the Furness Car Company.
Post #434996 15th Apr 2017 7:56pm
