Home > Technical (L322) > DRLs |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
Iid tool has the option to pick drl lighting.. |
14th Apr 2017 11:57am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
as alistair says..invest in a GAP iidtool and you can change many car configuration files [ccf] and have things like one press superlock, beep on lock/unlock, digital speedo readout [small but otherwise very useful] etc etc...
14th Apr 2017 12:03pm |
Freddie The Fish Member Since: 13 Apr 2017 Location: Bedfordshire Posts: 115 |
Thanks guys but with my technical prowess that sounds like a expensive way to make my car never work again or sound the horn every time it changes gear....😀
14th Apr 2017 12:15pm |
possibly if they have the correct diagnostic tool... ... - .- -.
14th Apr 2017 12:34pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1379 |
Switched my DRL's on with an IID tool. Dead simple, took less than 5 minutes. If you're not confident find a willing 8 year old 2017 4.4 SDV8 Autobiography
14th Apr 2017 2:24pm |
14th Apr 2017 4:17pm |
Seems a bit excessive just to get them activated, don't think I'd ever use it again after. Can't see why the dealer can't do it if it's possible. Will put the idea on the back burner and maybe hunt down a specialist one day to do it. |
14th Apr 2017 4:39pm |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 456 |
another option may be to find a willing owner and buy another vin code
14th Apr 2017 7:21pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7792 |
I don't believe the ever had DRL's from the factory. That law came in after they stopped making them - in the UK anyway. That's why it's not so easy to do and you need a decent diagnostic tool to modify the config. Not even sure a dealer would do it, but a decent Indy might..... 2011 Range Rover Vogue SE 4.4 TDV8
14th Apr 2017 7:31pm |
tbh the little leds on the headlights are a sad effort for a drl, very few and not very bright ...its best to convert the fogs like a few members [and me] have done.. ... - .- -.
14th Apr 2017 7:40pm |
Lad Member Since: 11 Oct 2014 Location: Blackburn Posts: 284 |
i don't think its a configurable option on the dealer tool. |
15th Apr 2017 10:26pm |
Thanks chaps, will survive without them as can't see the point in getting an iidtool just to turn them on.
16th Apr 2017 8:34am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
I set the option but as they were so dull I quickly returned to the Scandinavian headlight DRL option. |
16th Apr 2017 10:25am |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
I used my IID tool to use the mains as DRL''s .
16th Apr 2017 10:59am |
