Home > Technical (L322) > TD6 Transmission Oil Cooler
sarn
England 2002 Range Rover Vogue Td6 Epsom Green
Hi to one and all,am about to tackle fitting new transmission oil cooler on my 2002 RR Vogue. Does anyone have experience of doing this job? Manual States that Power Steering pump and Alternater need removing for access,but I was hoping once under tray was removed cooler could be removed from underneath. Is this wishful thinking? Any advice would be very much appreciated.
Post #428243 18th Feb 2017 12:52pm
miggit
Ignore the manual... it's written for people without imagination!!! Yes it can be got at from underneath once the tray has gone, I can't remember the details as it was a few years ago... but the fact that I don't remember means that there wasn't any issues.. And I have never removed the alternator or power steering pump on a TD6 L322!! Yesterday I couldn't spell Engineer... Today I are one!
Post #428254 18th Feb 2017 3:02pm
sarn
Thanks miggit will have a go at swop next week.
Post #428295 18th Feb 2017 7:20pm
sarn
Well at long last have swopped td6 transmission oil cooler (thanks miggit) for a new unit ( Island4x4). This operation cured my Year long problem of td6 over cooling. Sod's law - changed main thermostat,did away with EGR gubbins - all to no avail!
Happy Days Thumbs Up
Post #434908 14th Apr 2017 3:42pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Post #434932 14th Apr 2017 7:07pm
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
So, do you have to change the complete cooler when it over cools, or is there a replaceable stat in it?
Post #434937 14th Apr 2017 7:50pm
sarn
The transmission oil cooler has a built in - non replaceable - thermostat. Crazy I know as on close examination it certainly looks like it could be replaced! The OEM unit I purchased from island 4x4 was identical to the original unit but at a reasonable price (£130) .
Post #435180 17th Apr 2017 12:05pm
rodp
Thanks. Thumbs Up Easy enough job ? How long did it take you?
Post #435205 17th Apr 2017 2:59pm
sarn
As miggit says earlier in this topic,ignore the manual...remove plastic under tray, disconnect transmission oil pipe assembly and two coolant pipes. Catch fluids in suitable containers - I actually clamped off both coolant pipes to minimise losses. Remove 4 bolts securing cooler to block and remove. After re fitting new unit transmission oil will need topping up. Oh and new O rings should be fitted to transmission oil pipes/cooler coupling. Took me about 3 hours,not rushing. Hope this helps.
Post #435290 18th Apr 2017 2:29pm
rodp
Thanks for the info Thumbs Up May have to be doing this shortly. EGR stat done, engine stat next and if that doesn't cure cool running then it's this one.
Post #435304 18th Apr 2017 4:31pm
