Home > Maintenance & Mods (L322) > air suspension fault |
razzer Member Since: 20 Feb 2015 Location: blackpool Posts: 54 |
hi all, can anyone help, my L322 was parked for a couple of days on a slope when i went to use it the message "air suspension inactive flagged up, i also have a abs light on the dash, the front air spring are quite low but the rear ones are high, the raise/lower switch isnt iluminated. any ideas |
8th Apr 2017 11:37am |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 828 |
Have you carried out a battery disconnect yet? The proper procedure is in the wiki section above..
8th Apr 2017 1:20pm |
no other messages, i did try disconnecting the battery to no avail. |
8th Apr 2017 1:33pm |
Do you have diagnostics available?
8th Apr 2017 2:32pm |
thanks for your input |
8th Apr 2017 3:53pm |
