![]() | Home > Wheels & Tyres > Change 1 tyre or pair of tyres? |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1455 ![]() ![]() |
I always replace in pairs across each axle and keep the best of whats left as the spare.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8688 ![]() ![]() ![]() |
Agree generally with the above, its recommended, if your part worn and remaining good front tyre have the same tread depth then it won't be an issue as such, however its best to replace the pair, i would if i was off on a european trip.
WCA Member Since: 15 Jan 2017 Location: Hampshire Posts: 26 ![]() |
Tread on the part worn almost identical to what I will be replacing so seems a £££ tempting option to buy one rather than two tyres.
sounds like a good trip.
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Hi, sorry, but always replace the 4 tyres at the same time on a permanent 4WD(unless you dont mind replacing center diff/diffs), 2 by 2 are ok for 2WD only. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 544 ![]() ![]() ![]() |
I've seen this mentioned a good few times, but I can't see the reasoning behind it. The whole point of a diff is to allow differential speeds at the output shafts, hence the name, so why would the very small speed differences caused by new over part worn tyres cause a problem? Drives: 2010 FFRR TdV8 Vogue - Stornoway Grey 2010 FFRR TdV8 Vogue SE - Zermatt Silver 1998 BMW E36 M3 GTII |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
i bought a land rover used approved last May and they fitted two new tyres to compliment the other 6mm ones on the FF...if LR think that a difference of two mm is ok then i can't see a problem with just replacing two tyres.
