Home > Technical (L322) > Help !!! |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 828 |
To close the windows try and press your remote for total closure. Can't help with the key problem though - sorry.... ______________________________
30th Mar 2017 3:17pm |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 |
Thanks, absolutely nothing happening using remote, and have to leave the vehicle in 10 minutes for an appointment? |
30th Mar 2017 3:21pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
have you been sitting there listening to the radio?
30th Mar 2017 3:25pm |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
If you absolutely have to leave it as is and you have any tools then throw something over the ignition to hide the keys and disconnect the battery.
30th Mar 2017 3:35pm |
Not sure about this but, key in the door lock and turn to lock then hold. That should shut everything up unless has been said the battery is flattish.... ______________________________
30th Mar 2017 3:43pm |
Hmmm, I can take the key in and out no probs it just will not turn to position one even and as said cannot get hear selector out of park,
30th Mar 2017 4:26pm |
I'm back with the car now ( no one stole it while I was away ),
30th Mar 2017 4:33pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1374 |
This sounds like when my battery was completely flat, the car shuts itself down and does not let you do anything. See if you can get charge into the battery via jump leads/booster pack (this may take some time) and you might need to short the system out to clear the blockage. Apparently once the battery gets low enough the car shuts off all function and that needs to be cleared before the car will start again. The recovery technician that helped me spoke to LR Assist even though I didn't have that cover any more and they advised him what to do, one would hope they would do the same for you if necessary, 0800 521 786.
30th Mar 2017 4:48pm |
Ok thanks ( guess who left the XSPowerpack at home today after helping someone jump their car yesterday ?),
30th Mar 2017 5:01pm |
How do you mean " may need to short the system to clear blockages"? |
30th Mar 2017 5:04pm |
think they mean a battery reset.
30th Mar 2017 5:18pm |
Can't you call the AA? Or join them and then call? Might get you moving. Other breakdown peeps are available, obviously....
30th Mar 2017 5:38pm |
https://www.theaa.com/breakdown-cover/instant-cover
30th Mar 2017 5:40pm |
Yep RAC just confirmed the Alternator is no more ( could smell it when he connected some power ) and prob my new battery as it read 0.23v😮,
30th Mar 2017 6:02pm |
