Home > Wheels & Tyres > Thinking of changing to 18" wheels......
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
I'm currently running my 2006 FF on the standard 19" with 255/55 19 tyres but I'm thinking of changing to an 18" wheel.
Although I like the current wheels the tyres are going to need replacing in the not very distant future and I'd like to swap them while they're still road legal so I can refit them should I decide to change my RR in the future.
The reason I'm looking at 18" in particular is because I have a full set of Hankook Ventus ST 285/55/18" tyres (and wheels) off my Navara that I removed before disposing of it.
I'm selling the wheels and tyres off the Navara complete if I get the right money but I don't think I'll get what I believe they're worth to me, 2 tyres have about 4-5mm of thread and the other 2 are practically new with less than 2k km on them.
Now I know the purests will say to stick with the RR options but I haven't seen anything that really tickles my fancy.
I have spotted a set of wheels off a Discovery for reasonable money.
https://www.donedeal.ie/alloyswheels-for-s...campaign=6
Now I know everyone has different opinions on wheels, and I'd like to stick a big set of 22" on but I do a lot of driving on secondary roads or minor roads and I'm not sure 22"' alloys would be able to take it and I'd end up with cracks and buckles all over the place so from a practical point of view, and since I already have a full set of tyres I think 18" is my best option.
So, the basics for anyone with a good knowledge of these things, firstly, will those Disco wheels above fit my FF, it's a TD6 so I don't have the Brembo issue, also I have the silver nuts, will these need to be changed?
Are these wheels likely to be rated high enough for a FF?
And will my 285 tyres fit these rims (currently fitted with 255/60/18 tyres, 3 with min thread depth)?
All information, opinions and answers gratefully received.......
Post #433202 30th Mar 2017 12:51pm
hamlet
I should have said, changing from my current 255/55/19's to the 285/55/18's will only result in a 1% increase in diameter which I don't think should be an issue, I'm also really like the Ventus tyres when I had them fitted to the Navara, but that's not to say they'll perform as well in the RR, but I do like the wider tyre look.
Post #433203 30th Mar 2017 1:00pm
Weegie
Don't know if this helps. http://www.fullfatrr.com/forum/topic32993....+18+wheels
For interest, the earlier RRs had 18 inch wheels as standard. Mine is early MY2005 with 18s. John
GAP iiD BT
Post #433221 30th Mar 2017 2:52pm
hamlet
Thanks Weggie, I did a search but missed that one........ Embarassed
I've seen a few sets of 18" for the FFRR's but liked the look of these, plus the asking price isn't bad at €200, about £175 (sorry, the link wasn't working, fixed now).
Any issues with putting the 285 tyres on these rims do you think?
Post #433224 30th Mar 2017 3:09pm
Weegie
Sorry can't really comment on the 285 tyres. John
GAP iiD BT
Post #433264 30th Mar 2017 6:19pm
Check the loading on the tyres are upto what LR specify for the 18". Iirc the load is 112 but could be wrong. There is nothing that can't be fixed with a hammer😜😜
Post #433277 30th Mar 2017 8:07pm
rar110
With a td6 you will have a range of LRrims to choose from for a 285 tyre. Just make the offset is ok, load capacity is at least 900kg (especially if at normal speed on 2nd class roads), is 8" wide and is genuine LR rim. There are other good brands such as componotive. Just keeping it simple.
You should note a 285 tyre will not fit in the wheel well. I would carefully and physically check the diameter difference if intending to keep an original as a spare.
285/55/18 is not a very common size here so may not be easy finding one if one gets destroyed. I went to 265/60/18 as very common and fits in the wheel well.
Here's a comparison I did between a couple of sizes.
http://www.fullfatrr.com/forum/post429960.html#429960 ______________________________
Post #433282 30th Mar 2017 8:57pm
miggit
Why don't you fit 255/60/18's that is the correct tyre size for 18"wheels and there is no clearance issues Rolling Eyes Yesterday I couldn't spell Engineer... Today I are one!
Post #433295 30th Mar 2017 10:18pm
hamlet
Good point, I think the tyres I have are 113V, rated at 1150kg so should be ok, it's currently fitted with 111v.
@ rav110, thanks for the info., but are you saying that a 285 tyre won't fit in the wheel well? I'm getting different information on this, perhaps depends on the offset of the new rims, I guess fitting is the only real way of knowing.
According to the comparison calculator the between 255/50/19 and 285/55/18 would be +1% in diameter and circum., +12% in width and +12.7% in sidewall.
https://tiresize.com/tyre-size-calculator/
@ Miggit, I'm only considering 285/55/18's because I already have a set sitting at home (and I like the wider look tyres..... Embarassed ).
Post #433322 31st Mar 2017 10:54am
rar110
I tried a 285/60/18 in my L322 wheel well and it was too big. Even a 275 will be too big.
I've heard of people deflating tyres to fit a required space, or raising the cargo area floor. ______________________________
Post #433323 31st Mar 2017 11:14am
hamlet
Thanks again for the info., but I'm a bit confused, where exactly did your 285's not fit?
I've seen lots of posts about people running 285's, even up to 22", although with a lower profile tyre.
The difference between a 255/50/19 and 285/55/18 would only be +1% in diameter and circum., but a 12% increase in width.
Stan had 295/45/20's on RRS rims fitted to his TD6 FFRR, that's 3.6% wider and .7% taller that the tyres I'm proposing to fit.
http://www.fullfatrr.com/forum/post293933.html#293933
I have read that the offset would need to be 53mm or lower to clear the front struts and from a search I think the wheels I'm looking at have an offset of 53mm.
Post #433327 31st Mar 2017 12:53pm
increase in width will be 30mm so thats 15mm each side. if you have less than 15mm clearance between the inner sidewall and any components then it will foul, thats about a fingers width. There is nothing that can't be fixed with a hammer😜😜
Post #433346 31st Mar 2017 4:04pm
Surprised there's so much doubt about this. 285 isn't all that big. I've had 275 20s on two of my 322s and never had any issues with clearance (or anything else). Indeed I believe it was a "standard" oversize (Stormer alloys?) supplied by LR and was for sale in a main dealer near me for <£800 incl tyres.....at a time when I needed new tyres - so a no brainer for me at the time (on my '02). I think the car looked good on them, but obviously they didn't work as well for anything other than tarmac driving. I also had 275 Grabbers on my 4.2 SC an they worked well for me on and off road - although I see that Chris was keen to change them as soon as he could after he bought it! Mike - MPx
Post #433363 31st Mar 2017 6:11pm
hamlet
Thanks again guys, I think it's the offset of the wheels I'm looking at that could make the difference, there isn't a whole pile of room between the current wheel and the front strut but if the wheels I'm looking at have a different offset (in the right direction) then hopefully there won't be a problem.
I'm going to look at them in the morning, and hopefully get one of my own tyres fitted so will know a bit more then.
Thanks again for the input, I'll report back and let you know, cheers.
Post #433370 31st Mar 2017 6:50pm
Standard sizes
255/60 18
255/55 19
255/55 20
The 275/45 20 is a sport size and was never officially offered as a 322 fitment Thumbs Up
No t saying the 285's won't fit as the op says it's down to offset and spacing from the strut There is nothing that can't be fixed with a hammer😜😜
Post #433381 31st Mar 2017 7:57pm
