Home > Off Topic > Any TV / Satellite engineers here? |
As title chaps. What I want to know is whether satellite co-ax cable can be used on a free view aerial.
20th Mar 2017 9:19pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35281 |
not a tv engineer Dom but i've done loads of messing about with dishes and aerials and yes you can use sat coax as tv coax, if fact sat coax is slightly better screened so less signal loss on longer lengths.. ... - .- -.
20th Mar 2017 9:32pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
Might me easier to buy a freesat box than put up an aerial ?
21st Mar 2017 1:01am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
I have my free view aerial wired using satellite cable, never been a problem for the last 16 years. |
21st Mar 2017 7:32am |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
+1 for the FREESAT box. It's just plug and play with your sky connections. Previously..
21st Mar 2017 8:34am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2643 |
If you ask nicely, I probably have a direct male to rf screw fitting from my days as a cable guy lying around somewhere. |
21st Mar 2017 9:47am |
LOL, pretty please, with cherry on top
21st Mar 2017 10:03am |
Yes, feasible. I used to wire up systems like that, using passive splitters. Do not use those cack y piece splitters, they were ok in the 1980's ! Your TVs will probably at different ends of the house , migyt be easier fitting 2 separate aerials. |
21st Mar 2017 1:55pm |
Yes, there is already an aerial on one end of the house which would do the 2 upstairs TVs and teh wiring could go through the loft without issue.
21st Mar 2017 4:18pm |
Lol, I might have spare 2 way one |
21st Mar 2017 4:31pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
the cable will all be fine, we use the same cable for sat and TV when wiring up new houses and it works well.
21st Mar 2017 5:05pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
As others have said, sat cable is better, so can use for Freeview. You can't go the other way, though. |
22nd Mar 2017 11:54pm |
