Home > Maintenance & Mods (L322) > Slight judder when braking
Eric Cartman
Ireland 2010 Range Rover Autobiography TDV8 Santorini Black
Im getting a bit of a judder while braking, coming from the front left and shakes the steering wheel, nothing while accelerating or cruising.
Just went through a CVRT (Basically MOT in Ireland) test and front side slip / suspension / braking tests all come back fine and even. No uneven tyre wear and pads are fine too.
I have a slight leak in the power steering rack and it appears on that side, but no idea what it is. Current Vehicles :
L322 2010MY TDV8 Autobiography
BMW E38 735i
BMW E63 645ci
Post #431886 21st Mar 2017 12:19pm
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Binding Caliper?
Check if front left brake disc/hub is much hotter than the others after a short drive. Careful - could be very hot! African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #431910 21st Mar 2017 1:52pm
MattC
United Kingdom 2011 Range Rover Vogue SE TDV8 Alaska White
Warped disc?
Post #431914 21st Mar 2017 2:04pm
Eric Cartman
discs were done less than a year ago and the CVRT does a test on that, theyre very careful with brakes these days.
if the caliper was sticking, would I not see uneven pad wear on the front ?
just to clarify, it passed the test with this happening.
Interestingly today I was doing a trip, and when you get to 70+ mph and let off the accelerator you notice the front left pull slightly, Current Vehicles :
BMW E38 735i
BMW E63 645ci
Post #431917 21st Mar 2017 2:19pm
