Home > Maintenance & Mods (L322) > Front brake caliper bracket mounting bolts
Jorrocks
United Kingdom 2018 Range Rover Autobiography SDV8 Montalcino Red
Hi all,
I was about to change pads and discs on my 2009 L322 TDV8, all was going swimmingly until I tried to remove the bracket in order to free the disc. Bracket is held on by two bolts that are of a 12 point design. Can anyone tell me what tool is required in order to remove them? A 21mm 12 point socket seems to fit but I'm not sure it's up to the torque required to loosen the bolt, which is on tighter than a very tight thing! Do I need a torx socket perhaps, and if so, what size?
Many thanks in advance!
Post #431474 17th Mar 2017 10:36am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Just a 21mm socket on a lever bar will get them loose. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #431495 17th Mar 2017 2:31pm
Jorrocks
Thanks, I'll get to it with a length of scaffold pole at the weekend!
Post #431503 17th Mar 2017 4:13pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Two lengths of pole and a fat git required. In all my years, I'd never come across two bolts so firmly tightened .
Post #431524 17th Mar 2017 7:09pm
GraemeS
Use thread-locker when refitting them too.
Post #431525 17th Mar 2017 7:16pm
