Home > Maintenance & Mods (L322) > Replacing rotten boot floor on a l322 |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
at that sort of money unless you need the wheel well I would be tempted to just weld in a flat panel for the cost's, never heard of a L322 rusting badly in the boot maybe where the car's been kept ? |
6th Mar 2017 8:43pm |
Jonny789 Member Since: 27 Feb 2017 Location: somewhere Posts: 8 |
Thanks for the quick reply, the car itself is in pretty good nick, it's just from the rear wheels back which makes us think it's been used for launching boats in the sea possibly? Once the new floor is welded in we will be shot blasted the rear underside of the car, we are a little concerned as the rear crossmember the air bags sit on looks quite scabby, are the l322's prone to rot in these areas ? |
6th Mar 2017 8:50pm |
not heard of a l322 being very rusty in boot area at all, they do suffer with wheel arch's |
6th Mar 2017 9:36pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 |
Have a look under the sill covers towards the rear of the car, there may be some rust under there....... ______________________________
7th Mar 2017 9:23am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1378 |
I recall another thread which showed bad rust around the bottom corner of the rear wheel arch, coming from inside the panel. There are also threads on water collecting in the spare wheel well from leaks above. Only Range Rovers since 1988 |
7th Mar 2017 11:49am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7800 |
Yea...water can gather in there if there is a leak from the rear tailgate seal, or sometimes from the bolts in there that hold the back bumper on.
7th Mar 2017 2:09pm |
Here's the photos of the corrosion, after a poke about we are glad we bought the expensive Land Rover repair panel now
7th Mar 2017 2:25pm |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
Hey Jonny789
7th Mar 2017 6:59pm |
The car is a 2003 car but has had the 2012 lift done, looking round it inside and out you would think it is only 5 years old.
7th Mar 2017 7:28pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Mine's also pretty horrible for rust. Just eeking out it's remaining life. It is 15 years old later this year so it's not something to be upset about. |
7th Mar 2017 10:16pm |
Sorry about the sills, I had a feeling.
8th Mar 2017 8:44am |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
My boots gone in the same place, so you aren't the only one.
8th Mar 2017 1:23pm |
8th Mar 2017 2:25pm |
8th Mar 2017 2:27pm |
