Home > My Range Rover > Just got my first FFRR! 2003 Vogue 4.4
Page 8 of 8 <12345678
mr_spock
I serviced the LPG today, with new filters. It was a pretty easy job except removing the snap rings holding the gas filter together. I do have some snap ring pliers, but they are for smaller ones really. Still, got there in the end - to find that one of the crimped hose ends on the low pressure side was leaking when moved. The crimped hose clip had failed, such that I could rotate the hose easily by hand. Chopped the end off and replaced with a Jubilee clip and all is good!
Next weekend - spark plugs.
Post #393185 26th Jun 2016 6:42pm
mr_spock
Well, I still haven't done the spark plugs. First MOT tomorrow and am nervous! One headlight is a little reluctant to start and the handbrake is a bit weak, but we'll see. The same place does alignment so I'm getting that done too.
Post #410974 27th Oct 2016 6:32pm
Good luck mate... Thumbs Up Pete
Post #410996 27th Oct 2016 8:12pm
mr_spock
Just had a call... and....
FAIL.
On an indicator side repeater! Asked them to change the bulb since it's trivial, they have the car and I need it. They're also doing a 4-wheel alignment, and say it needs 5 adjustments at £15 per adjustment. Seems OK, and I hope it will improve the drive.
More later...
Post #411124 28th Oct 2016 1:16pm
mr_spock
I have an MOT, and the 4 wheel alignment has definitely made tight corners ore comfortable. Can't wait to get it above, er, 60 or so and see if the slight shimmy has gone.
Any my steering wheel is straight! OCD is happy!
Post #411147 28th Oct 2016 4:41pm
Clivefog
The slightly off steering wheel that you got used to is now straight, now you have to get used to that! The driving pleasure is enhanced, hope the shimmy has gone.
Post #411312 29th Oct 2016 6:29pm
mr_spock
Just a follow up... the wheel was still slightly off, and I'd had a slow tyre leak diagnosed as a leak at the rim. But, after the alignment I started getting a 'clonk" on some uneven tarmac. Took it back yesterday, diagnosed a knackered track rod end and noticed that they'd actually fixed the leak on a wheel that didn't have a leak!
Got a Lemforder end from ECP, took it in and got it back this afternoon with steering wheel straight, no clonking, and they'd road tested it and balanced the front wheels too which were "way out".
Smooth as silk now!
Well done to Stevenage Tyres - took 2 hours, only charged me for 1, one suspension adjustment for the new track rod end and some wheel weights.
Please God let that me it for now!
Post #415338 25th Nov 2016 3:17pm
Don't be silly... plenty more is waiting, just waiting for that time you think, this car is going really nice now, then
BONG Pete
Post #415377 25th Nov 2016 6:54pm
mr_spock
No bong today. Well, key battery low, but it's kind of new. However, after having a kangarooing fit yesterday while running on petrol (OK on LPG) it wouldn't start this morning. No codes.
I'm guessing fuel pump - yes, I checked the fuse and swapped the relay. Trailered to Aylmer as I don't have time to look and I'm away on business for a few days.
Bah. Bloody thing.
Post #430232 6th Mar 2017 2:12pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
May be only the saddle tank pump - do u have more than 1/4 tank of fuel in?
Also isn't there a way to"hard start" on lpg whilst engine is below the switchover temp?
Post #430347 7th Mar 2017 10:59am
mr_spock
Confirmed as the in-tank pump. I don't have the time to apply the lower cost fix of an X5 pump, so will just have to swallow the cost. BRC system has ho way to force an LPG start that I can see.
Post #430349 7th Mar 2017 11:08am
mr_spock
Today's fun. I'd noticed that the brake dust shield on the nearside was a bit rattly when I changed the strut. So today I popped the wheel off, removed the caliper, removed the disk and bolted the shield back on with some penny washers. Very easy job, helped by the recent disc/pad change so all bolts were easy to remove!
Satisfying job.
Post #431561 18th Mar 2017 11:09am
mr_spock
In the slightly warmer weather a few weeks ago I noticed the air con wasn't particularly cold. My local garage does a £21 regas through Groupon for sub-3L cars, so I called them and agreed that price for my 4.4. An hour later and I have ice cold a/c again!
Due an oil service soon...
Post #437668 9th May 2017 1:04pm
Dolphinboy
Hi spiky, which fuel pump did you end up using and what cost and from where?
Post #437780 9th May 2017 9:49pm
mr_spock
Hi, sorry I didn't reply. The fuel pump was supplied by the specialist, probably a factory LR one as they use genuine parts.
Anyway, update...
I replaced one rear door lock, then the other one went. Then I moved house - so will get to that as I have a new one in a box somewhere. Did the filters for the oil service and will change the oil next week...
once the new gearbox is in. Yes, gearbox death. Whining, slipping a bit, torque converter judder, so it's going in tomorrow for a box rebuild, converter and oil cooler flush (or replacement).
Which is a pain as I was about to part-ex it as my mileage is going up substantially. So if anyone wants a very well maintained L322 4.4 with LPG, digital TV and a new, warrantied gearbox it will be on here soon.
Post #453656 10th Oct 2017 10:04pm
