Home > Maintenance & Mods (L322) > Drivers window stuck down at 11pm!!!
stucart
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Stacker, thanks, that explains why Dan not replied then, will try my local dealer with part no and Vin, will also try Furness. report back later. Cheers.
Post #426711 7th Feb 2017 11:47am
stucart
Not having much luck, no one appears to answer phone at 2 dealers! Emailed Furness via Ebay shop. Sad
Post #426715 7th Feb 2017 1:06pm
stucart
Rang my local indy and asked who they use for genuine parts, gave me a No.
rang spoke to helpful guy, gave him part no. vin and reg, he came up with amended part no YUD 502020, assures me its right one so ive ordered it should be here tomorrow hopefully. £149.22 + VAT. Once its turned up and is correct i'll give them a mention, fingers crossed this sorts it. Very Happy
Post #426733 7th Feb 2017 4:31pm
mr_spock
As you have a 2007, this may be nonsense, but... with the switch disconnected, if you lock the car and hold the key in the locking position, do your windows/sunroof close? Maybe open another window and see if that one works. That would eliminate the switch.
Post #426877 8th Feb 2017 2:15pm
stucart
Spock, don't think it did that before when everything was working. Tried it to see if it put window up but it didn't after fault developed. New switch has arrived but not going have time till Friday fit it👍
Post #426936 8th Feb 2017 6:56pm
I think you will find it has to pass through the switchpack to raise the window no matter how you trigger it...
The IID will trigger it the same way the global close works which is via the BECM but you have to have a switchpack in place for it to work... Thumbs Up Pete
Post #427077 9th Feb 2017 5:56pm
stucart
Its fixed Very Happy
But not without problems, new switch unit arrived, fitted it after checking window raised and lowered ok, then discovered only passenger mirror folded or adjusted??
Tried old unit both mirrors folded and adjusted??? Faulty new switch!!!
Another one obtained and delivered by supplier, connected and tried before fitting properly, ok. Refitted it to door card and refitted it all, ....Then l try all functions and one mirror is out other is folded in wtf??, press switch and they swap over still one in one out!!!
Remove door card remove mirror plug and press button, passenger mirror folds to match drivers, connect plug and they are now in sync, phew..............finish refitting door card, try everything again all working. time for cup of tea Thumbs Up
Big thanks to Dave at Land Ranger services ltd Middlewich Thumbs Up
ps Purchased FullFat RR .com stickers for RR , wouldn't have sorted this without your help, cheer all who helped.
Post #427219 10th Feb 2017 6:01pm
