Home > General > The most nicked cars in France
bebechoon
France
According to AutoPlus, a French weekly motoring magazine, the most nicked car in France in 2016 was the E-wok, with 196 stolen per 10,000 insured, with the “Range Rover / Range Rover Sport” not far behind, in 4th position (156 / 10,000)!
The reason given for the high LR representation is the ease with which thieves can get in and programme a ‘key’ in less than a minute using a box of electronic tricks costing a couple of thousand Euros, plus the fact that these – and other premium models – can easily be sold on.
The article (in French, oeuf Corse!) can be read on http://news.autoplus.fr/Land+Rover/Range+R...12783.html although you need to buy the mag to see the full list. (I can supply if anyone is interested, if you ask nicely …)
Is the story similar in the UK, anyone?
 It's "bĂ©bĂ©choon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 7 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #425121 27th Jan 2017 9:53pm
Rob99
Some info here.....
http://www.fullfatrr.com/forum/topic37676....tolen+list 2017 4.4 SDV8 Autobiography
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #425177 28th Jan 2017 9:18am
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
I don't know about the Evoque but the FFRR has a deadlocking system on the second press (in my case); how are they getting around that?
Post #425235 28th Jan 2017 3:50pm
bebechoon
France
Having done a bit of searching, I see that RR thefts have been discussed quite a lot here. See for example http://www.fullfatrr.com/forum/topic32310.html
Interestingly, in this thread http://www.fullfatrr.com/forum/topic25743.html, it seems the thieves got inside the car by smashing a rear door window. Once inside, they were able to programme a new key.
I really don't know but that must be one way of getting round the deadlocking. I’m sure others can provide more info …
Previous:
Disco II
Post #425243 28th Jan 2017 4:29pm
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I think the weakness for access is keyless entry.
If a car is parked on a drive with the keys indoors but near, I think the thieves can use a device to amplify the signals between the car and the key so the car thinks the key is close by and allows entry.
The latest models don't allow a new key to then be created from the OBD port and my MY2106 has had an update to achieve his.
Not sure how many earlier LR vehicles are being similarly updated
Post #425255 28th Jan 2017 6:14pm
Giantlandyman
That's why I am a little confused.
The keyless entry on mine is turned off so the button needs to be pressed to open. The keyless start is active. Why would the key and car communicate with the keyless entry turned off? Or am I being naive?
And once the car is deadlocked, the volumetric alarm is active so breaking a window should set it off....?
Post #425282 28th Jan 2017 7:54pm
Rob99
Didn't think the L322 had keyless entry? How do you enable it? CCF setting maybe? 2017 4.4 SDV8 Autobiography
Post #425358 29th Jan 2017 9:22am
Giantlandyman
You're quite right, Rob; sorry. I am nothing if not thoroughly incompetent Embarassed
I think I am more confused now, seeing as the key fob needs pushing to unlock from single or double lock.
Post #425623 30th Jan 2017 1:58pm
Rob99
Damn, was getting all excited there for a minute....... Big Cry 2017 4.4 SDV8 Autobiography
Post #425625 30th Jan 2017 2:01pm
I had a recall for my MY2013 at my local dealer for an software update for this. All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #425649 30th Jan 2017 4:03pm
markyp
England 2004 Range Rover Vogue Td6 Zambezi Silver
There was a feature on this on watchdog on the Beeb a while ago, They had a Range Rover, Audi,and a bm all keyless,
Matey was there with his box of tricks and unlocked and started each car in less than a minute. 2004 vogue
1978 Pontiac Firebird
2010 Fiesta
Post #425659 30th Jan 2017 5:37pm
martinf
So I keep my keys in a faraday cage (aka a key safe) to prevent thieves gaining access even though they can no longer use the OBD port to create a key.
Post #425668 30th Jan 2017 6:38pm
Bebert53
France 2011 Range Rover HSE TDV8 Stornoway Grey
Just wait a little next year the def will be in the top ten
i am afraid i have one L322 and one Daffy
Big Cry
and a bicycle
Cool
Post #425683 30th Jan 2017 8:09pm
Iirc the L322's don't suffer as much with this as much as newer 405's do sue to the keyless setup which is then used in the sport and epoke. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #425900 1st Feb 2017 6:02pm
sump
Keyless always cause headaches.
Post #426266 4th Feb 2017 4:30pm
