Home > Technical (L322) > CTEK charger question |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
I think the red collar is so the plug can be used on more than one type of socket e.g. standard cigar lighter and 'NATO' type socket which is a lot smaller. It shouldn't cause any drain if left in because the collar is plastic (non-conductive) and the rear socket is permanently live anyway. |
22nd Jan 2017 3:46pm |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 |
Ah right, so it needs to come out and maybe I should glue it onto the plug part then ya reckon? |
22nd Jan 2017 4:04pm |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 226 |
The red collar converts between. Din and cigarette lighter plug, so without it you have a Din plug.
22nd Jan 2017 4:48pm |
Ok thanks,
22nd Jan 2017 5:49pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7790 |
Does it not like turn to lock in place? 2011 Range Rover Vogue SE 4.4 TDV8
22nd Jan 2017 7:28pm |
espaceboy Member Since: 02 Aug 2014 Location: Fae Fife Posts: 86 |
glue works fine |
22nd Jan 2017 7:34pm |
Not that I could see, does yours ? |
22nd Jan 2017 7:42pm |
