Home > Technical (L322) > Windshield wiper relay |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35278 |
also found this in the WM....item number 9 is the wiper relay,
17th Jan 2017 4:33pm |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 383 |
So let me ask this question. The windshield wipers when turned off, stop about mid screen. Are there 2 relays? 1 for wipers and one for intermittent wipers??? |
17th Jan 2017 10:14pm |
Hi All,
18th Jan 2017 1:54am |
One more question. The reason I am replacing the windshield wiper relay is that the wipers are stopping mid screen when turned off. I was told it might be the relay?? Has anyone else had this problem?
19th Jan 2017 11:01pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
That sounds more like a fault with the parking sensor in the wiper motor... as the dealer said yank the fuse first and see if that does it.. the relay can cause problems, but it normally fails by not sending the park signal to the ECU.. then it has a fit and stops the wipers for a few minutes.. not much fun when the only time you know there is a problem your using the bloody wipers because its raining
19th Jan 2017 11:45pm |
Thank you!! The new relay will be here tomorrow and if it doesn't work i'll look at the motor! |
20th Jan 2017 3:14am |
Installed new relay and it didn't fix he problem so now looking at new windshield wiper motor. |
21st Jan 2017 2:57am |
AB54FLY Member Since: 18 Jan 2015 Location: Manchester Posts: 3 |
Believe it or not I've just had exactly the same issue, 2007 4.2SC. My wipers would park at 90 degrees, once in a while at 45. Replaced the relay in the box in the engine bay yesterday, the one you have replaced. Exactly the same result - no difference.
21st Jan 2017 1:27pm |
Thanks AB! I'm not sure of tearing into the windshield wiper, it might be a little to much for my mechanical skills. Where is the motor located? Thanks! Mike |
21st Jan 2017 4:16pm |
Well, on my right hand drive car the motor is on the right hand side of the car. It's directly under the scuttle (the grill at the bottom of the windshield), inside the engine compartment right at the back. Access on mine wasn't too bad. A 13mm nut holds the fulcrum arm to the shaft, then 3 10mm bolts hold the motor to the bracket.
21st Jan 2017 5:32pm |
Wobbly Nuts
21st Jan 2017 6:35pm |
