Home > Technical (L322) > Radio-water problem....
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Hi all
Radio stopped today making strange noises and light flashes as usual.
This time i found water dips inside closet and cables coming from rear bumper side are wet.
Will try to clean both inside etc.
Any suggestions??????
Post #423225 17th Jan 2017 9:55am
most likely that you need a 'water shedder' ...contact dan @ duckworths for a price..
also check the tailgate seal as that lets in water when worn..
Post #423234 17th Jan 2017 10:24am
umitbat
It is already done.
Water is likely come from under and back of the car.
It had an accdent from left rear by prev owner.
Not well built under maybe.
Post #423263 17th Jan 2017 12:06pm
umitbat
After plug out-in the fault light disappeared but there is no sound at ignition on,only when i start the car sound is on but low volume sound not going up when i turn the knob.
I stripped contact cleaned dried the amp but the same.
Likely some capacitor or smt is gone.
Post #423316 17th Jan 2017 3:47pm
umitbat
No suggestions???
Post #423348 17th Jan 2017 6:31pm
umitbat
Does sound system have a protection mode?
Everything works fine instead of high volume.Sub kicks fine too.
Will try battery reset.(tried the same)
Post #424241 22nd Jan 2017 1:09pm
