Home > Technical (L322) > Alternator Belt changing incl. tensioner.... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35280 |
this should help,
5th Jan 2017 5:04pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
Uli, it's not a really easy job.
5th Jan 2017 8:08pm |
Found it...http://www.fullfatrr.com/forum/topic40761....alternator There is nothing that can't be fixed with a hammer😜😜
5th Jan 2017 8:10pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 316 |
Hi guys, thank a lot for your quick answers, good help, so I will bring the car to the official.... it is Clients car, and this work seems not so easy like the changing of the cracked oilcooler in the V (just done), and afterwards I saw the tnesioner and the belt, the belt only runs 80% around on the tensioner, and the belt squeeses also very loud, when I spray Silicon on it, the noise goes away for 20 seconds....,
5th Jan 2017 8:16pm |
if its running off the tensioner then its possibly the tensioner which is failing. i recall Craig mentioning that a few months back. There is nothing that can't be fixed with a hammer😜😜
5th Jan 2017 8:36pm |
OK, Sir! Have orderd the tensioner at official for monday, will build out the tensioner first, and will clean the belt (because some coolant swaped above him), and will fix. For cleaning the belt you have some ideas? The beast is the black one in waiting Position for Workshop. Best rgs, Uli
5th Jan 2017 9:05pm |
something like this, got some for mine which stopped a small squeak, for a while.
5th Jan 2017 9:26pm |
OK, good product, will buy tomorrow in cars-supply-store. Also I believe good is (german word: HIRSCHTALG), White material for door-gaskets in winter. L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
5th Jan 2017 9:28pm |
gummi pfledge is what we have over here.
5th Jan 2017 9:33pm |
Or this, will buy also tomorrow at my shop...
5th Jan 2017 10:20pm |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 |
belt is real easy remove engine tray slacken fan shroud feed new belt around fan and with someone underneath with a leaver feed belt around pulleys and use leaver on tensioner slip belt into place and wala one new belt no fuss exept bolts on tray which there are many good luck |
6th Jan 2017 1:29am |
@rik, my english is not so perfect, that I understand your kind response..., but here a picture of the tensioner....
7th Jan 2017 8:06am |
NEW tensioner, old belt, all is 100% perfect, no squezzing, no noises, car runs wonderful, also the oilcooler is perfect, no leaks more! Thanks a lot to all gentlemen here!
10th Jan 2017 10:03pm |
sorry my mistake i thought 4.4 v8 petrol just did mine and it was real easy glad you got it soted |
11th Jan 2017 12:38am |
