Home > Technical (L322) > Lumbar Support stuck on how-to
beavercarr86
Scotland 2003 Range Rover Vogue 4.4 V8 Java Black
So I have had my driver's seat lumber support fully inflated for a while and finally lost the rag with it today and started digging for the problem. Evil or Very Mad
I looked allot online and on various forums for answers, with little or no valuable input to be found, bar a not too bad idea of a big pin! There was talk of a pressure release solenoid from someone who then had no help further as to where this was or how to operate it.
Anyways i started digging with the actual lumbar switch and there was life somewhere in the seat when i pushed the pressure release button but no release of pressure. I then, snapping all the clips as i went, removed the switches and swapped them from passenger side to driver side, this eliminated the switches as passenger side works perfect. Still no solution.
I then started digging around for the pump and bladder in the seat.
I found if you lift the seat to the highest position and pull full forward everything at the back is much easier to access
Before
The pump and bladder are located behind here
First remove the two stretchy straps holding the back cover taught. These are attached to the seat springs underneath
I then folded it up out the way and clipped onto the seat pocket
The there is two crews under the seat, these are Torx T25
Otherside
Then the seat back just lifts up and out. RAVE says to remove armrest. I found i wiggled it out and back in with no dramas
Here's what you find, inflated, back breaking bladder, indicated
Here the inflation and deflation hoses
I pulled them out a bit and found two connectors, i tried to break these to release the pressure but found them far too tight to loosen Big Cry , so i investigated further
The hoses disappear behind another section to the pump and solenoid
I found you could slide off the cover for this as shown
Here's what's behind
The Pump and the Solenoid
Blue is inflation, Red deflation, so i popped the connection off and released all the pressure in the bladder, then jumped in the seat and made sure i pushed all the pressure out and that the seat was super comfy again. Thumbs Up
Only left to reassemble, I found that putting the cover back was a Censored
The just a case of lining up the guide with the two holes below and at the armrest and sorted Very Happy
I hope this helps anyone else with a similar problem. I suspect my solenoid is jammed and not releasing the pressure when the switch demands. I left the red deflation hose off as I'm very happy without the lumbar support Laughing I would also discourage people taking off the seat sides if they don't need to as I broke ALL the clips and now its a little shaky both sides.
[/img]
Post #417151 8th Dec 2016 3:38pm
nice job, wiki'fied Thumbs Up ... - .- -.
Post #417153 8th Dec 2016 4:08pm
