Home > Technical (L322) > Drivers seat cools but no hot air?
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
As above, the cooling works, blower switches on, turning the switch to cool, but no reaction when turned on to warm my buns? Anyone of this well informed crowd knows what to do?
Oh and yes I cleaned the filter. Thanks in advance.
Post #412525 7th Nov 2016 12:32pm
similar problem maybe here,
http://www.fullfatrr.com/forum/topic10106.html ... - .- -.
Post #412527 7th Nov 2016 12:38pm
philcorsa
France 2008 Range Rover Vogue TDV8 Buckingham Blue
hello
have the same problem on my RR
strip the back rest seat, the pipe was broken, the ecu shut down the fan but leave the light on. RR L322 4.4 TDV8 Vogue
RR L322 3.6TDV8 Vogue
Disco TD5 HSE
RR P38 4.6 HSE v8 GPL
Disco 3.9 V8 GPL
Disco 3.5 V8 GPL
RR 300TDI
RR 2.4 VM TDI
Land Commando
Post #412541 7th Nov 2016 2:40pm
Robert
thanks Stan, had not searched well enough..
thanks Phil
The only thing that is different is the blower/fan working for the cooling. So it can't be the fan.
We'll have a look in the chair... Sad
Post #412544 7th Nov 2016 3:06pm
philcorsa
on mine the fan run normally to cool the seat, but not heating as ther's a security
if the pipe is broken there's no air running through the heat resistence, too hot so the ecu shut down the fan RR L322 4.4 TDV8 Vogue
Disco TD5 HSE
Disco 3.9 V8 GPL
Disco 3.5 V8 GPL
RR 300TDI
RR 2.4 VM TDI
Land Commando
Post #412546 7th Nov 2016 3:27pm
Robert
Thumbs Up graci mille
Post #412558 7th Nov 2016 5:21pm
On heating it needs a temperature reading for the ECU and as the pipe is probably broken it over reads and shuts down , on cooling the circuit goes closed loop and carries on happily for now but will fail in time . Seat out I'm afraid Big Cry I'd almost recommend just ordering the Peltier cell now I'm so certain it's the broken pipe Thumbs Up 2008 MY Supercharged
Post #412619 7th Nov 2016 11:57pm
