Home > Technical (L322) > Can you identify this connector? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I'm trying to identify the make of this connector, so that I can get a plug that is the same...
21st Oct 2016 3:48pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Scotchlock ? (Starts flame war! )
21st Oct 2016 9:22pm |
Might not be 'ang''over related, but thought I'd sand a better chance near the top of the forum Yesterday I couldn't spell Engineer... Today I are one!
21st Oct 2016 10:30pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
Looks similar to the VW part number 1J0 973 803
21st Oct 2016 10:51pm |
Actually scrap that VW part number, that's the 1.5mm wide tab version.
21st Oct 2016 10:55pm |
That was as far as I got.. I thought eureka when I stumbled on the VW plug... and then relised that it was a 1.5mm blade... I'll try and get some more info off the plug, but it's right at the back of the engine bay and buried under a load of fuel and cooler pipes Yesterday I couldn't spell Engineer... Today I are one!
22nd Oct 2016 12:05am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
What vehicle is it off and what is it connected to? |
22nd Oct 2016 12:09am |
It's Mercedes ML 270 CDI swirl flap actuator..... I've just had to do a delete, but to fool the ECU and stop it going into limp mode you have to add to the circuit... at the moment it's just pushed in to the plug... but it's not a good fit. I'm not that worried about cutting the loom and joining in the patch.. but if it could be made plug and play... there could be a few quids to be made And it would be easily reversible too
22nd Oct 2016 8:47am |
It may be worth having a google for Bosch 3 pin connector and looking at images or mercedes 3 pin connector or bosch weatherproof connector but select images and try and find one that looks similar and then go to the page. That's how i found the connectors i needed for my sidelights.
22nd Oct 2016 2:02pm |
Well after much faffing about (right at the back of engine bay, under windscreen, and coolant tank )I discovered that the plug was made by Kostal and it's restricted supply and there is no plug
24th Oct 2016 2:22pm |
Well after a sort 3 week delay the plugs turned up..Perfect where would we be without Ping Pong's copyright laws Yesterday I couldn't spell Engineer... Today I are one!
16th Nov 2016 2:31pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
and all for £1.39 delivered .... ... - .- -.
16th Nov 2016 2:37pm |
I wish, you need to move the decimal point to get nearer the price.... but at least it came in less than the VAT threshold, so HMRC didn't get to add their pain to it Yesterday I couldn't spell Engineer... Today I are one!
16th Nov 2016 2:41pm |
