Home > Technical (L322) > rear wiper washer |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
Take a look here - http://www.fullfatrr.com/forum/topic9924.html Got - 2017 SDV8 Autobiography in Loire Blue
18th Oct 2016 10:31pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
That's perfect...thanks! |
19th Oct 2016 4:08am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
You don't need the screws, when you've taken it apart, you can pop the old seal out of the black plastic bit.. The replacement seal will then sit deep in the black bit, and then you can glue it back in place with some epoxy resin (rapid works best, but get the cheap stuff from toolstation )
19th Oct 2016 6:05pm |
That sounds even better! Ordered some seals earlier from amazon.couple of quid delivered..will pick up some epoxy resin Friday and that's my Saturday task on the full fat..cheers again buddy |
19th Oct 2016 7:11pm |
This is the stuff that I used http://www.toolstation.com/shop/Adhesives+...sin/p29905
19th Oct 2016 10:58pm |
Just picked up the same stuff Hopefully seals delivered today so I can get it fixed today...another job ticked off the to do list shortly! This forums great! Saved a fortune on repairs |
20th Oct 2016 10:26am |
Miggit...it worked a treat buddy! Did everything you advised and the epoxy did the trick! Thanks again guys .. |
22nd Oct 2016 6:11pm |
Your welcome Bud Yesterday I couldn't spell Engineer... Today I are one!
22nd Oct 2016 10:15pm |
Earl of Ankh Member Since: 25 Sep 2016 Location: Devon Posts: 1 |
Having read this post and having the same issues myself I decided to give it a go. Washer jets now cleaned and working and the wiper arm lubricated and sitting nicely on the rear window.
12th Nov 2016 3:04pm |
stu_007 Member Since: 25 Jun 2016 Location: Cardiff Posts: 177 |
I was going to give this a go but ended up buying a complete new motor. "YYS" G4 FFRR
12th Nov 2016 7:30pm |
^ I think you wasted your money Got - 2017 SDV8 Autobiography in Loire Blue
12th Nov 2016 8:17pm |
Shame on you It really isn't much harder that a Blue Peter job.. only there is no sticky back plastic involved Oh the good old days... when there wasn't a safe Fairy liquid bottle in the land I have always used the philosophy that you can't break it anymore than broken, but you might be able to fix it and save a fortune Works for most things... although I haven't had much luck with tyres Yesterday I couldn't spell Engineer... Today I are one! Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
12th Nov 2016 11:05pm |
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 |
did away with mine going though the motor and put dual sprays on mine and wow has made a great difference can actually see from back window when driving down really dusty sites |
13th Nov 2016 12:36am |
