Home > Technical (L322) > Gearbox slip |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
Have you had it from new...?? If not has it got a towbar..??? run it hard with a big weight on the back and you will very quickly wear out the oil prematurely, if it was mine I would get the oil changed straight away, oil is cheap, a gearbox isn't... I'd also get the codes read to see if it is flagging up something...
13th Sep 2016 5:34pm |
simonreed Member Since: 14 Jun 2016 Location: hampshire Posts: 11 |
Hi,
13th Sep 2016 6:01pm |
There will be a filter or screen in the bottom of the gearbox sump... many an argument on here whether it should be changed or not... personally I can't see the point of not changing it...
13th Sep 2016 7:13pm |
