![]() | Home > General > Highest mileage BMW V8s? |
Josh Wyatt Member Since: 10 Jan 2011 Location: Oxford Posts: 77 ![]() ![]() ![]() |
I had a '52' L322 V8 with 210,000 or so miles I looked after/sold in 2012. I've just checked the MOT history online and it's still going with 235,000 on it.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
as Ive commented on this before, i'll summarise, my 02 v8 now has 166k, it was pro LPG fitted, at 60k, and I bought the car, at 144k, with broken chain guides. I repaired it and re-sealed the vanos gears. So, ive now done 20k ish, and all good, but with a weeping coolant loss, I recently did my valley pan gasket, and fitted the lower temp thermostat.
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
This high mileage thread; a similar thread started over on the D3/D4 forum....people were mainly around 150-200k but then an ex highways or ex police D3 that was now a long distance driver was still going with over 750k on the clock...and rising !!
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Hi John,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8394 ![]() ![]() ![]() |
I am just in the process of doing a what if and how to for the thermostat replacement as everyone seems to be wanting info now... bit busy at the moment but it won't be long...
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1547 ![]() ![]() |
See http://www.fullfatrr.com/forum/topic38399.html In there, you'll find links to my pics. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
If you dig into it i think you might find only the shell and chassis and some other bits are original, i know the engine and gearbox certainly arent ![]() Mantec Sump Guard, Rigid Load liner, MY10 BT upgrade. ![]() |
Starberg Member Since: 08 Jan 2015 Location: Karlskrona Posts: 70 ![]() ![]() ![]() |
http://www.bimmerfest.com/forums/showthread.php?t=93207 L322 Vogue 2003 |
That's "Character"'s car which he uses to tow a car trailer delivering motors all over the country. It had a new engine at about 500k but it really is Trigger's Broom. Plus it's a diesel which tend to be longer lived than petrols. Certainly not one to use as an example of the life of components, there's nothing original on it. ![]() |
Don't forget I think he's so sick of it he's finally moved over to a beaver tail merc sprinter conversion thing or similar now |
As Pete fitted his identical thermostat kit, over a year before I did mine, and he knows his way around a toolbox, I would trust his forthcoming write up. It's basically a £50 (via a German supplier,) kit, with longer bolts, and some spacers. You have to saw off the old thermostat holding 'wings' and file them flat, and assemble it, and bolt it back on. (Same housing) and although it doesn't feel 'cool', it is running cooler. About an hours work. |
^^^ danke schön |
