Home > Technical (L322) > Cold Starting Diesel?
Kilovolt
United Kingdom 2010 Range Rover Vogue TDV8 Atacama Sand
We (like many others no doubt) hit minus 11.2 degrees on Friday night. Shocked
Both the Disco (TDV6 MY2009 with 50k Miles) and the FFRR (Vogue TDV8 MY2010 with 12k Miles) definitely had a cylinder or two 'missing' on start-up.
Disco has a manual key so you have to wait for the heater light to go out before cranking but the FFRR has a start pushbutton so the computermerbob does the countdown on the heaters before cranking the engine.
Disco 'fired' straight away (so to speak) and within 20 seconds went to smooth running and the FFRR fired up well and went to smooth runnng almost instantly really. But both were definitely a 'bit rough' on the first few start seconds.
Me thinks these things are designed to work in much colder climates than this and they should not 'appear' to be missing at all Question
Any thoughts (or experiences) from the collective and these recent cold start events please?
Thanking all in advance. Thumbs Up Currently running FFRR MY10 TDV8 3.6L and a Disco 3 XS Commercial (tank like but very effective as a Company van). Plus one mint condition Track Day Car in the form of an E36 M3 3.2L Evolution circa June 1996 with lots of go faster bits and only 52k miles on the clock! Oh, plus a few bits to make it slow down really quickly as well! Luvverly.
Post #39986 29th Nov 2010 11:46am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Mine is the same, starts, just feels a bit rough.
But I'm glad it at least starts!
Post #39987 29th Nov 2010 11:50am
My 2006MY Vogue SE Supercharged is not liking the cold either. Its starts first turn but immediately dies unless you give it a touch of throttle. It is then a bit lumpy for a few minute while warming up. First few seconds it smokes just a little too.
After about 2 minutes its as sweet as a nut again but I agree its not quite right for a tough nut vehicle like the Range Rover. Neutral
Post #39991 29th Nov 2010 12:00pm
Richcl
I wonder if the filling stations have changed to winter fuels yet? Confused
Post #39992 29th Nov 2010 12:03pm
Fox
Not noticed any difference here, but think it's only been down to -4.
I always use the Fuel Burning Heater though when it's chilly. Thumbs Up
Post #39993 29th Nov 2010 12:06pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Hi Gaz, don't know if it helps (sadly my LTB list is on my laptop at home)
There was a software update for the SC which dealt with the weak 'catch' on startup and rough idle for a couple of seconds. I only found it because I thought it was Voltage related but still got it after I changed my battery.
The symptoms were usually worse in cold or if it was left standing for a long period and basically on turning the key the starter would crank then the engine would hesitantly catch and huff and puff for a second or two until it settled.
May be worth a look.
Post #39994 29th Nov 2010 12:11pm
When you get home could you post the LTB number please. Very helpful thanks. Thumbs Up
Post #39995 29th Nov 2010 12:27pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Well having been out in the 110 earlier... where you have to manually hold the glow plug position for about 15 - 20 seconds before considering a very lumpy start it is still pure luxury.
You wouldn't want the 110 to get hot mind.. thay might mean the icicles hanging from the sunroof start to defrost.. and its purely condensation at that too!
Shocked 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #40125 29th Nov 2010 9:15pm
If the battery hasn't gone flat (again, due to the cold and me being too lazy to replace it at the moment - the trusty MX5 and some jump leads to the rescue), my diesel takes a few more revolutions on the starter than normal to get it to fire up ( I always wait for the glow plug light to go out !), and then apart from a bit more clattering than normal from the engine, runs smoothly straight away. .
Post #40146 29th Nov 2010 11:06pm
piecost76
I use Wurth winter diesel additive as a precaution on both my cars. So far no problems at all, not even on initial start up...
http://www.wurth.co.uk/catalogue/pdfs/UK-CD_06_0007.pdf
Then again, I'm down south but in the sticks too Whistle Quis custodiet ipsos custodes?
15 MY 110 XS USW
54 FFRR Vogue TD6 Touchscreen - Gone!
56 FFRR TDV8 VSE - Gone!
Post #40165 30th Nov 2010 11:03am
-8 here last night and I started the TD6 without waiting on the glow plugs heating. nice and smooth on start up and no misfire
Post #40200 30th Nov 2010 3:50pm
Stephen.125
@Gaz:
LTB00016/2006
and maybe
LTB00197/v2/2009
Post #40244 30th Nov 2010 7:50pm
