Home > Technical (L322) > Front flap fitting Q's?
T24RES
Can anyone who has fr/flaps fitted tell me if you or the dealer had to carve the inner wing in this fashion?
Regards
Post #39866 28th Nov 2010 2:56pm
That looks so wrong. You should not need to cut the liner
Post #39869 28th Nov 2010 3:02pm
Thats the way mine look and it was a LR dealership that fitted them ........... Thumbs Up
Post #39870 28th Nov 2010 3:04pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
if this is what they look like then neither i or a dealer will be fitting......
Post #39899 28th Nov 2010 5:44pm
Fox
Surely doing that means the crud doesn't go on the outside of your bodywork, but instead can go up inside?
Post #39900 28th Nov 2010 5:48pm
I fitted LR units without cutting but you do have to drill and remove Side intakes to fit correctly. All in the instructions.
Post #39909 28th Nov 2010 6:53pm
skippy
United Kingdom 2007 Range Rover Vogue SE TDV8 Rimini Red
mines the same too looks like somebody has taken a axe to them Shocked 07my 3.6 tdv8 vogue se in red
Post #39930 28th Nov 2010 8:53pm
T24RES
I will be requesting new liners, as butchery wasn't required nor requested.
Post #39931 28th Nov 2010 8:56pm
T24RES
Banging Head
Post #39933 28th Nov 2010 8:57pm
T24RES
Booked into the dealer wed, new inner arch. And a few other gremlins, drivers heated seat base not getting hot, tyre valve broken and a yoky as a spare in place of the pirellis. App the sales manager only authorised a budget tyre. Yeah right, after the money I've just spent.
Post #39976 29th Nov 2010 10:28am
Fox
Time to find a proper dealer rather than cowboys pretending to be one?
Post #39981 29th Nov 2010 10:49am
T24RES
In fairness the service manager was spot on this morning. Only owned it since friday. Second hand buys are not a perfect experience but the dealer will get the hang of it. Wink
Post #39983 29th Nov 2010 11:32am
