Home > Technical (L322) > Battery reset
David
Spain 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Battery reset
It seams quite simple, turn off, open bonnet wait 10 mins. Remove battery terminals, wait 10 mins. Touch together for a couple of seconds and re connect.............. job done ?????
I keep seeing things like reset the steering sensor, window sensor etc..... So my question is, is it really as simple as the prosess above or will i have all sorts of things going on when i reconnect ???? Ive even read of someone haveing to have there car towed after replacing the batery !!!!
Post #39726 27th Nov 2010 1:45pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
If you have a system that needs a reset, pull it's fuse for 10 minutes..... Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #39727 27th Nov 2010 1:46pm
dan_uk_1984
You can fry your nav computer doing this, especially when you reconnect the battery, if you miss the terminal and it turns on and off in quick succession etc.
It's a last resort thing...
Post #39731 27th Nov 2010 2:04pm
David
Hi Dan
Its the last resort for my DVD player in relation to my post about mecha error ?
I dont fancy the sound of it to be fair !!!!!!!
Does anyone knoe the part number or a DIRECT replacment for the DVD player ?
Post #39732 27th Nov 2010 2:08pm
On the 4.2 S/C "R" Jaguar you have to input a specific code after battery replacement (although there is another way Smile). Is this the case with a Jaguar based 2006+ Range Rover?
Post #39763 27th Nov 2010 4:10pm
dan_uk_1984
David wrote:
Hi Dan
You should be able to get the part number from microcat... Isn't it an Alpine unit? I believe the DVD unit in my car is different to yours though.
Post #39768 27th Nov 2010 4:30pm
See halfords are doing a battery fitting charge for £4.99p ........ could save a lot of hassle ...... Laughing
Post #39770 27th Nov 2010 4:43pm
Mick do you have a larger version of your Avatar please as I am mesmerised
Post #39772 27th Nov 2010 5:20pm
Laughing Laughing Laughing Sorry they are all set to forums size .... Thumbs Up
Post #39777 27th Nov 2010 6:12pm
David
dan_uk_1984 wrote:
David wrote:
Hi Dan
if i could get microcat to work proply i would !!!
Post #39820 28th Nov 2010 9:18am
