Home > Technical (L322) > 4.4 tdv8 hesitation at 80 mph'ish |
Trantorman Member Since: 13 Oct 2012 Location: aberdeen Posts: 157 |
Thanks I missed that, I will check with the dealer this week |
17th Jul 2016 5:55pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7925 |
How frustrating Stan - another trip to France required |
17th Jul 2016 7:00pm |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 |
My car is goin into the stealers for the brake hose recall next week and i am getting them to have a look at this while its in. Where can i read the details of bulletin LTB00054v2 (has someone got a copy??)
17th Jul 2016 8:10pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35274 |
i'm tempted Alistair... ... - .- -.
17th Jul 2016 9:08pm |
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 |
Had this on my 2011 - dealer checked when it was on for last service, also swapped to posh diesel - stopped now. 😎 2005 L322 Vogue Gold gone
17th Jul 2016 9:33pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
It appears that LTB00054 is not the correct bulletin because that number is for D3 headlight condensation and therefore probably best not to quote that number to a dealer. V2 is just an updated release of the original bulletin, not of a different topic. |
18th Jul 2016 6:05am |
i looked on topix and i beleive its LTB000454v2. ... - .- -.
18th Jul 2016 6:52am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
Isn't posh diesel petrol or do you mean chip fat |
18th Jul 2016 7:36am |
Had the recall done today as well as the TSB update and a 4 wheel align. The gearbox is much better now, much more eager to change gear and smoother
26th Jul 2016 6:27pm |
i also had my software update done when the discs and pads were replaced...as you say Paul there is a difference but ive not had the opportunity to try it out to see if it still hesitates at speed.. ... - .- -.
26th Jul 2016 6:30pm |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 455 |
I have had this done too and there is a very marked improvement.
26th Jul 2016 6:48pm |
Still considering a gearbox oil change even though it no longer feels necessary. It has done 90k on what I am guessing is the original oil. If that improves it even more I will be a happy bunny. May be early days but since picking it up the mpg has improved slightly too
26th Jul 2016 7:08pm |
i to am tempted to get the gearbox oil changed , i wonder what kind of money that would cost.. ... - .- -.
26th Jul 2016 7:09pm |
I know the oil is more expensive on the 8 speed and it cannot be flushed like the 6 speed due to a built in thermostat that isolates the oil cooler until operating temperature so it's just a case of changing what you can in the box (probably about 50% of the total capacity) but at least some of the oil will be new?
26th Jul 2016 7:18pm |
