Home > Technical (L322) > Do I have a problem |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8192 |
Probably the wrong fluid in the gearbox... did they use the correct fluid, there is only one and that is Mobil LT71141 other oils will say they are the same specification but they don't have the correct additives...
5th Jul 2016 7:08pm |
Skip720 Member Since: 12 Jun 2016 Location: Wakefield Posts: 32 |
I took it to Quattro care in York who are Land Rover specialists. How could I tell what fluid they used? |
5th Jul 2016 7:13pm |
....and how do I check level.? |
5th Jul 2016 7:14pm |
You will have to ask them what oil they used and checking the oil level is a job for them, not easy to do on your own if you don't do DIY.... Pete
5th Jul 2016 7:23pm |
My lad is very handy (train mechanic) would he be able to check level? And thank you for your advice |
5th Jul 2016 7:25pm |
Engine running, on level ground. Oil in gearbox at around 30-50deg C... move selector through all positions, pausing in each for a few seconds, remove oil filler on the drivers side rear of the box with engine still on and ensure it is full until oil comes out, do not switch off engine with filler plug out or you get covered in it...
5th Jul 2016 10:20pm |
Double post... Pete
5th Jul 2016 10:21pm |
Thank you for that. I have e mailed Quattro care and will check level Asaph. Thanks again |
6th Jul 2016 5:38am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
from my experience of driving same car/gearbox, with low fluid level, (had a leak) you tend to get a slight snatching of the gears, when turning corners, i think more on a left turn, and box sort of goes into 'neutral' and then gurgles, and snatches the gear. -when just normal driving. keep it in mind. also, it sort of took a second to go into gear, when selecting the correct gear, especially from cold.
6th Jul 2016 6:19am |
Can the gearbox oil be overfilled? If so is it detrimental.
6th Jul 2016 7:23pm |
Pretty hard to overfill it, you pour oil in until it comes out, difficult to get it to stay in when you try to put the filler plug back in...
6th Jul 2016 8:23pm |
Cheers for that Pete. I called the guys that did flush and they said it is Mobil lt 71141. I have ordered a litre of said oil off eBay and I will try and put that in.
6th Jul 2016 8:41pm |
You really should download Rave as I said above it tells all.....
6th Jul 2016 10:03pm |
Thanks Pete, that's great. |
7th Jul 2016 1:43am |
