Home > Technical (L322) > low range
low range
a query for all of you that are mechanically minded...when i'm in low range and i brake i get a very loud rubbing/grinding noise, now would that be my brakes making that noise or is there a transmission brake of sorts in low range... ... - .- -.
Post #38341 23rd Nov 2010 12:39pm
Fox
Is this at low revs?
I found the brakes on my Td6 struggled more to stop the vehicle for the last few mph in low box due to the increased torque going through the drivetrain.
No transmission brake for low range. Only the handbrake.
Post #38345 23rd Nov 2010 12:43pm
i forgot to add that sometimes in normal high range i get the same noise but much quieter so what you have just said richard confirms my thoughts that the brakes need doing on the back....must be the brakes struggling with the increased torque.... btw are the shoes used when using the foot brake or only the discs... ... - .- -.
Post #38350 23rd Nov 2010 12:48pm
Fox
What shoes?
Only ones I was aware of are on the transmission for the handbrake.
Post #38353 23rd Nov 2010 12:53pm
are there not brake shoes behind the rear brake discs which i believe are adjustable via a small hole in the disc... ... - .- -.
Post #38360 23rd Nov 2010 12:56pm
Fox
Are there? Laughing
I'm off for a look.
Post #38362 23rd Nov 2010 12:58pm
They are the handbrake shoes
Post #38370 23rd Nov 2010 1:07pm
so thats the answer then , increased torque putting a massive strain on the braking system....must get them rears changed now. Thumbs Up ... - .- -.
Post #38374 23rd Nov 2010 1:09pm
Fox
Thinking of my Defender. Rolling Eyes
That has the handbrake on the rear of the transfer box and no rear shoes.
Post #38375 23rd Nov 2010 1:09pm
Correct, all the older LR models had the handbrake at the rear of the transfer box in typical LR fashion. Modern LR vehicles are as standard car set up
Post #38377 23rd Nov 2010 1:11pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Even with new pads all round mine still makes a lot of noise when in low range and using the brakes.
Normally when trying to level the caravan on ramps.
Ian
Post #38953 24th Nov 2010 1:05pm
cheers for that ian, i am again re-assured that its nothing serious... ... - .- -.
Post #38961 24th Nov 2010 1:22pm
