Home > Maintenance & Mods (L322) > New owner with a couple questions!
Mann3210
Scotland 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Hello to all on the forum, I've just purchased a 2007 4.2 V8 SC Vogue se, which is superb I've had several old series 3 & defenders but this is my first RR, I'm interested in finding out about doing the 2010/12 face lift. Can someone give some advice on this mod? I was thinking of doing the rear first & the side vents. Then the front which I'm guessing will be parts intensive! Also I have the front & rear TVs but no headphones or remote, can I just pick these up from Land Rover or is there a cheaper option? Thanks
Post #385892 8th May 2016 10:18am
Weegie
Welcome aboard.
Just for you http://www.fullfatrr.com/forum/topic24581....conversion Thumbs Up John
GAP iiD BT
Post #385893 8th May 2016 10:35am
peekay
2016 Range Rover Autobiography SDV8 Corris Grey
There is a for sale thread which I think contains the items you want - here http://www.fullfatrr.com/forum/topic37514.html
Post #385894 8th May 2016 10:38am
Mann3210
Thank you buddy! Much appreciated
Post #385895 8th May 2016 10:39am
Mann3210
So I have read that how 2 for the conversion! Looks straight forward, anybody able to point me in the right direction for the resistor/wiring for the LED lamps to work correctly?
Post #385918 8th May 2016 2:26pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Everything you need is in my guide (second reply link) the from lights just have 1 resistor for the indicators, the rear lights have to have a complete interface (available from eBay)
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos âžž YouTube.com/RangeRoverOwner
Post #385978 8th May 2016 10:11pm
Mann3210
Thanks Matt, I've managed to get a pair of 2012 tail lamps with a couple interfaces brand new for less than £400! So that's on its way, I have a 2007 supercharged, in your how 2 it says I don't need to modify the wings, just remove & replace the brackets & just to be clear the 2007 washer system is good enough or do I still require to change any part of the washer system? Thanks again
Post #386931 13th May 2016 7:07pm
mattstevenson2005
You should just be able to change the brackets on the wings, there just a bolt on part. Not 100% on the washer system on a 07+ you need the more powerful washer pump for the 2012 bumper washer jets, if you have 2 standard pumps and 1 larger pump on your washer fluid bottle already you will be good to go, if you have 3 standard pumps you will need the later 2010+ style bottle and pumps.
Good luck and if you need any more he'll let me know, and don't forget to post pics when your done! Thumbs Up
Matt Current
Post #386938 13th May 2016 7:54pm
Mann3210
Well that saves a lot of messing around! Where is the washer bottle? I'll try & get a look in to see what I have fitted. Thank you so much for your help! Oh one last thing, what head lamps do I go for? I want the black ones the same as your RR, I don't think I have lamps that move around but I do have corner lamps!
Post #386943 13th May 2016 8:16pm
mattstevenson2005
The washer bottle is on the passenger side at the bottom just in front of the wheel arch liner. You can access it by unbolting the bottom of the liner from the under body engine cover then carefully bending it back and you should be able to access the bottle.
For the black headlights it's the 2012 model lights you want, Dan from Duckworths is your best man for the exact part number for the style of lights you want with the features you need. My car doesn't have the AFS system or corner lamps.
Matt Current
Post #386951 13th May 2016 8:38pm
Mann3210
Superb! Thanks, I've just checked, my lamps do move when I steer so I'm guessing its AFL
Post #386976 13th May 2016 11:33pm
