![]() | Home > Maintenance & Mods (L322) > New owner with a couple questions! |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3247 ![]() ![]() ![]() |
Welcome aboard.
peekay Member Since: 07 Nov 2011 Location: London Posts: 91 ![]() ![]() |
There is a for sale thread which I think contains the items you want - here http://www.fullfatrr.com/forum/topic37514.html |
Mann3210 Member Since: 08 May 2016 Location: Perthshire Posts: 56 ![]() ![]() ![]() |
Thank you buddy! Much appreciated |
So I have read that how 2 for the conversion! Looks straight forward, anybody able to point me in the right direction for the resistor/wiring for the LED lamps to work correctly? |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
Everything you need is in my guide (second reply link) the from lights just have 1 resistor for the indicators, the rear lights have to have a complete interface (available from eBay)
Thanks Matt, I've managed to get a pair of 2012 tail lamps with a couple interfaces brand new for less than £400! So that's on its way, I have a 2007 supercharged, in your how 2 it says I don't need to modify the wings, just remove & replace the brackets & just to be clear the 2007 washer system is good enough or do I still require to change any part of the washer system? Thanks again |
You should just be able to change the brackets on the wings, there just a bolt on part. Not 100% on the washer system on a 07+ you need the more powerful washer pump for the 2012 bumper washer jets, if you have 2 standard pumps and 1 larger pump on your washer fluid bottle already you will be good to go, if you have 3 standard pumps you will need the later 2010+ style bottle and pumps.
Well that saves a lot of messing around! Where is the washer bottle? I'll try & get a look in to see what I have fitted. Thank you so much for your help! Oh one last thing, what head lamps do I go for? I want the black ones the same as your RR, I don't think I have lamps that move around but I do have corner lamps! |
The washer bottle is on the passenger side at the bottom just in front of the wheel arch liner. You can access it by unbolting the bottom of the liner from the under body engine cover then carefully bending it back and you should be able to access the bottle.
Superb! Thanks, I've just checked, my lamps do move when I steer so I'm guessing its AFL |
