Home > Technical (L322) > 2007 SC just died 150m from home |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
How much fuel indicated in tank? Previous cars:
3rd May 2016 5:58am |
Dieterf Member Since: 24 Apr 2016 Location: Cape Town Posts: 40 |
full, actually full and shows full |
3rd May 2016 6:02am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
battery, alternator, broken belt? ... - .- -.
3rd May 2016 6:37am |
Maybe the alternator packed up and it hasn't been charging the battery properly ?? Or fuel line/filter clogged or fuel pump fooocked. Have you got a IID or Faultmate for reading the codes ? MY 2010 5.0 SC Galway green and sand interior!!
3rd May 2016 6:38am |
Mistercorn Member Since: 01 Feb 2014 Location: Nottingham Posts: 109 |
If the car was running and it came to a halt, and you cranked and cranked until the battery went flat and it still wouldn't start, that points to pretty much anything except a battery/charging issue to me. More likely fuel.
3rd May 2016 7:38am |
YUP, i concur.
3rd May 2016 7:45am |
JamesD Member Since: 21 Jan 2013 Location: Worcestershire Posts: 203 |
Sounds like fuel pump to me, get someone to listen near the tank when you turn to ignition II to hear it prime. If you want to check fuel pressure, take the pipe of the rail and run the same test, check it's getting to the motor.
3rd May 2016 7:59am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
Fuel pump, crank sensor, cam sensor, would be my first three things to look at...
3rd May 2016 11:04am |
Due to work commitments I pushed the car into the garage until I am back on the weekend.
3rd May 2016 2:54pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8501 |
you can find the wiki link in the top right hand corner of the page under the fullfatrr.com and advertisers banners (in red) or otherwise the links in stans signature will take you there. There is nothing that can't be fixed with a hammer😜😜
3rd May 2016 3:55pm |
Thank you
3rd May 2016 4:05pm |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
Washed car, wet battery area, mysterious electrical fault. Too much of a coincidence for me. I would check out that area first, make sure everything is dry and all connections are good. |
3rd May 2016 4:10pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
Maybe you could try disconnecting the battery for 15 mins, and reconnecting.
3rd May 2016 4:45pm |
YUP, I agree, wash-wet battery-problem!
4th May 2016 4:30am |
