Home > Technical (L322) > low range |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35315 |
a query for all of you that are mechanically minded...when i'm in low range and i brake i get a very loud rubbing/grinding noise, now would that be my brakes making that noise or is there a transmission brake of sorts in low range... ... - .- -.
23rd Nov 2010 12:39pm |
i forgot to add that sometimes in normal high range i get the same noise but much quieter so what you have just said richard confirms my thoughts that the brakes need doing on the back....must be the brakes struggling with the increased torque.... btw are the shoes used when using the foot brake or only the discs... ... - .- -.
23rd Nov 2010 12:48pm |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
What shoes?
23rd Nov 2010 12:53pm |
are there not brake shoes behind the rear brake discs which i believe are adjustable via a small hole in the disc... ... - .- -.
23rd Nov 2010 12:56pm |
Are there?
23rd Nov 2010 12:58pm |
They are the handbrake shoes |
23rd Nov 2010 1:07pm |
so thats the answer then , increased torque putting a massive strain on the braking system....must get them rears changed now. ... - .- -.
23rd Nov 2010 1:09pm |
Thinking of my Defender.
Correct, all the older LR models had the handbrake at the rear of the transfer box in typical LR fashion. Modern LR vehicles are as standard car set up |
23rd Nov 2010 1:11pm |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
Even with new pads all round mine still makes a lot of noise when in low range and using the brakes.
24th Nov 2010 1:05pm |
cheers for that ian, i am again re-assured that its nothing serious... ... - .- -.
24th Nov 2010 1:22pm |
