Home > Maintenance & Mods (L322) > BAS Remaps for TDV8 3.6
proser
Has anyone on here had the IID Tool remap from BAS, if so what is their view on the change from standard ?? Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #382934 20th Apr 2016 8:24am
I had the pre-IID remap from BAS - it used to come on a separate box that plugged into the ODB port.
I was very happy with mine - gains will be subjective - but it certainly picked up better and in particular it seemed to fix a kind of low end flat spot I had, so coming off roundabouts was much smoother.
Post #382939 20th Apr 2016 8:36am
proser
Thanks.
Did it cure the issue where sometimes pulling away would be - put foot down on pedal, ecu receives signal then has a think about it and then applies power and off you go Regards
Mark
2012 Westminster
Post #382941 20th Apr 2016 8:40am
Sounds like the one - I did mine 2 days after buying it 6 or 7 years ago - but remember clearly a hesitation in acceleration and the BAS unit fixed it.
Post #382943 20th Apr 2016 8:53am
proser
good to know Thumbs Up Thumbs Up Thumbs Up Regards
Mark
2012 Westminster
Post #382950 20th Apr 2016 9:33am
It fixed mine too on my old 3.6... Thumbs Up
And yes, it was a BAS remap Bow down
Post #382959 20th Apr 2016 10:45am
proser
Thanks for the 2nd vote of confidence.
I have ordered the map and just waiting for the email to start the process. Regards
Mark
2012 Westminster
Post #382961 20th Apr 2016 10:49am
rar110
One day, with iid tool. ______________________________
Post #382963 20th Apr 2016 11:02am
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Did mine via the tool last month.
Excellent results.
Post #382993 20th Apr 2016 6:53pm
proser
the total process is soooooo easy Thumbs Up
Went for a little drive (had to get some spray paint for the proper Mini) and a very noticeable difference on pickup Bow down Will give it a good try on Saturday as need to go to Coventry for son's football. Regards
Mark
2012 Westminster
Post #383029 21st Apr 2016 7:30am
From memory, it takes around 75 miles to work to its potential i believe sir? Thumbs Up
Post #383030 21st Apr 2016 7:33am
proser
Thumbs Up cheers Craig Regards
Mark
2012 Westminster
Post #383031 21st Apr 2016 7:34am
Post #383033 21st Apr 2016 7:38am
Glad to hear it's still a painless service - when I got mine, Pete was so responsive it was crazy - He was mailing me map updates on a Sunday when he was on holiday Shocked Thumbs Up
Post #383035 21st Apr 2016 7:40am
