Home > For Sale & Wanted > [SOLD] Land Rover Professional Diagnostic Scan Tool - iC
Realist
Wales
Land Rover Professional Diagnostic Scan Tool - iCarsoft LRII LR2.
Purchased this on the 10-Feb-16 via EBay via the main supplier and paid £165.00 for it, now I've purchased a IID Bluetooth I no longer need this hence the sale.
This is in mint condition, used no more than 3 times just to read codes and put back in the box.
Some details about the reader.
The iCarsoft range of 2nd Generation Diagnostic Tools offer full system manufacturer specific diagnostics. Providing detailed descriptions and likely reasons as to why your vehicle is showing Engine, Auto Transmission, ABS, Airbag and more Diagnostic Trouble Codes (DTC's) and can clear those stored codes. A totally unique product and amazing value for money - enabling technicians to accurately diagnose complex problems and now enables you to easily carry out the same.
+ Oil Service Reset Function...
The iCarsoft 2nd Generation Diagnostic Tools allow you to reset Oil Service Lights in a click of a button on supported vehicles. On vehicles where a manual reset is required, the tool will guide you through the full process step-by-step.
+ EPB Reset Function...
Brake Pad / Shoe changes on vehicles equipped with EPB's (Electronic Parking Brakes) MUST be carried out using a Diagnostic Tool to correctly re-calibrate. The iCarsoft 2nd Generation Tools offer you that capability on supported models. De-activate to Service Position - Replace - Re-activate.
EPB Modules are very expensive to replace when damaged! Don't take the risk!
+ ECTS Reset Function...
After cleaning or replacing the Electronic Throttle Body (ECTS), adaptation must be carried out (also the case if the negative terminal of the battery has been disconnected or when the Engine Control Unit has been replaced). The iCarsoft 2nd Generation Tools will perform Electronic Throttle Body adaptations on supported vehicles.
+ SAS Reset Function...
The Steering Angle Sensor (SAS) is used to measure the angle of the steering wheel and the speed at which it is being turned. The signal is mainly used by the ABS System as part of it's stability control function but also by other systems such as ride level control and adpative lighting. A problem with the SAS Signal will cause a fault with any of the systems that use the signal directly, or indirectly.
If the Steering Angle Sensor (SAS) needs to be changed, many vehicle's require the new sensor to be calibrated. The iCarsoft 2nd Generation Tool will allow you to carry out steering angle re-calibration on supported models.
+ DPF Regen or Replacement...
Carry out a forced Diesel Particulate Filter (DPF) Regeneration on supported vehicles - this MUST be done by trained personnel. Required when the DPF filter blockage reaches levels where passive or active regeneration is unable to burn off the excess soot. The iCarsoft 2nd Generation Tool is also capable of adapting a new DPF Filter where supported.
Our EXCLUSIVE Model Coverage
*All tools purchased from the Official UK iCarsoft Outlet at UK Parts Direct are supplied with EXCLUSIVE Full Land Rover AND Jaguar Model Coverage*
Land Rover Defender - 2001-2004 √
Land Rover Defender - 2007-2012 √
Land Rover Discovery 2 - 1999-2004 √
Land Rover Discovery 3 - 2004-2010 √
Land Rover Discovery 4 - 2010-2016 √
Land Rover Freelander 1 - 2001-2006 √
Land Rover Freelander 2 - 2006-2014 √
Land Rover Range Rover (P38) - 1999-2002 √
Land Rover Range Rover (L322) - 2002-2013 √
Land Rover Range Rover (L405) - 2012-2016 √
Land Rover Range Rover Evoque - 2012-2016 √
Land Rover Range Rover Sport - 2005-2016 √
*Please refer to our UK Parts Direct Website for full model coverage tables*
Key Features
•- Full Colour 4.0" TFT Display
•- Super Fast, Full System Coverage
•- Read, Diagnose and Clear Extensive Diagnostic Trouble Codes (DTC's) including Engine, Auto Transmission, ABS, Airbag and so much more
•- Service Reset Function (where available)
•- Electronic Parking Brake (EPB) Reset and Calibration (where available)
•- Electronic Throttle Control Reset (ECTS) (where available)
•- Steering Angle Reset (SAS) (where available)
•- Diesel Particulate Filter (DPF) Regeneration or Replace (where available)
•- Read Live PCM Data Stream (where available)
•- Extremely easy to use
•- Stand-alone Operation - No Laptop or Batteries required
•- Comprehensive Help - including DTC Library Database
•- Multi-Lingual Menu and DTC Definitions - English, French, Dutch, German, Portugese, Spanish, Italian and Russian
•- Software Upgradeable via TF Card
Looking for £130.00 [b](Reduced £125.00) via Paypal or BT.
Regards[/b] Range Rover quotes.....
The Luxury That�s More Than a Luxury.
Conquer the world, and look good doing it.
Built for the unexpected.
Over prepared, but never underdressed.
2007 Vogue SE TDV8 Epsom Green (old car).
2010 Discovery 3.0L GS Mk4 Black.
Post #379042 23rd Mar 2016 3:48pm
Realist
Wales
Just reduced it by £10.00 just to help its sale and give someone a chance of buying a good reader. Range Rover quotes.....
Post #379075 23rd Mar 2016 7:05pm
Realist
Wales
Reduced £125.00 quick sale. Range Rover quotes.....
Post #379233 24th Mar 2016 4:11pm
Realist
Wales
£120.00 anyone.
Not going any lower keep it as a spare, last chance. Range Rover quotes.....
Post #379251 24th Mar 2016 6:32pm
Realist
Wales
Anyone interested? Range Rover quotes.....
Post #379345 25th Mar 2016 11:50am
Realist
Wales
Bump....
Only used 3 times boxed. Range Rover quotes.....
Post #379926 29th Mar 2016 12:40pm
garethep
Is this still available?
Cheers
Gareth
Post #380118 30th Mar 2016 7:34pm
Realist
Wales
Yes. Range Rover quotes.....
Post #380126 30th Mar 2016 9:06pm
garethep
PM inbound!
Post #380129 30th Mar 2016 9:30pm
tony1kenobee
England 2003 Range Rover Autobiography 4.4 V8 Zambezi Silver
Hi, has this been sold? Cheers Tony
Post #380311 1st Apr 2016 10:37am
Realist
Wales
Nope still available. Range Rover quotes.....
Post #380356 1st Apr 2016 4:53pm
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
is this scanner still for sale
Post #380520 3rd Apr 2016 12:00pm
Realist
Wales
Yes it is. Range Rover quotes.....
Post #380626 3rd Apr 2016 10:37pm
Realist
Wales
SOLD. Range Rover quotes.....
Post #380772 4th Apr 2016 8:56pm
