Home > Technical (L322) > TD6 5L40E Gearbox rebuild - Aylesbury |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 |
Despite hopeful preventative maintenance since 50k miles (annual draining 4L and replacing Texamatic 7045E transmission fluid + filter/sieve replacement) my gearbox lost all drive just before 120k miles.
9th Mar 2016 1:42pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I saw that there yesterday when I dropped my silver one off Yesterday I couldn't spell Engineer... Today I are one!
9th Mar 2016 2:32pm |
Ah - they did mention that they had one coming in where the TC had been done already! |
9th Mar 2016 5:51pm |
smighall Member Since: 15 Jan 2015 Location: West Sussex Posts: 68 |
Do you mind giving me an idea on the cost for them to do the above work? |
9th Mar 2016 8:51pm |
They quoted me £1800 + vat for a full rebuild, which bearing in mind they fit a fully recond valve block and TCC, it would appear to be a very keen price, That's what I paid 18 months ago and it didn't include the valve block... which has added to the early demise of my box , just wish I'd found STA before..... Yesterday I couldn't spell Engineer... Today I are one!
9th Mar 2016 10:18pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 962 |
I note from their website that they have a Hydra-Test valve body test machine (with VBDaq data acquisition software), which is always a good sign. Anyone that invests £30k to ensure that they can thoroughly test the performance of their rebuilt valve body assemblies clearly cares about the quality of their re-manufactured transmissions (in my book, at least).
10th Mar 2016 1:29pm |
Open torque converters are brilliant at isolating driveline torsional vibration – and particularly for diesels. The torque converter lock-up clutch ‘continuous slip’ mode is there for a good reason – to help isolate torsional vibration at lower engine speeds while still reducing converter slippage for fuel economy. Once the engine (vehicle) reaches higher speeds, locking the converter up solid is fine. I think therefore that you’d have to be very careful if you’re considering eliminating the ‘continuous slip’ mode, though admittedly the GM converter does at least have a torsional vibration damper – the ZF 5-speed doesn’t. Who is supplying and programming these ECUs? Can you get some reassurance that they have vehicles running for high mileages using these settings?
10th Mar 2016 8:00pm |
Thanks Phil - no assurances given from the modified ECU sellers I suspect (http://www.ecotuning-automatic.de) and I don't want additional vibration from the gearbox which now behaves properly:
11th Mar 2016 3:38pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
From all the info I have gained in 2 to 2.5 yrs. I have come to the conclusion the GM 5L40E g/box is not up to the job.
11th Mar 2016 8:03pm |
VaguelyVogue, unless your doing something drastic with your ffrr, like someone else on here ( not naming names, but a good looking chap, well my mummy thinks so ) a fully rebuilt box with the sonnex valve mods should return something near to the original gearboxes mileage. Especially with regular oil changes
11th Mar 2016 9:26pm |
Totally agree mate. We are stuck with the GM box. For reference, my auto g/box specialist said, of the sonnex valve conversion, it wasn't worth the investment, in tools that is. As I'm not thinking of keeping the car for the next 80k or so, I didn't go for it.
11th Mar 2016 9:51pm |
11th Mar 2016 10:09pm |
GLOG update after 9 days driving:
18th Mar 2016 3:08pm |
