Home > Maintenance & Mods (L322) > 2003 4.4 V8 oil leak
Declan303
Ireland 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
I did a 2nd gearbox oil change today after driving for 2 weeks following 1st oil change plus filter. While under the FF, I couldn't but notice that I have an oil leak that is wetting the bottom of the engine, bell housing etc. It's not the gearbox sump which was removed and refitted with new gasket 2 weeks ago. Its definitely somewhere on driver side of engine. I can see the rear corners of the rocker covers and both of them have a mild seep but not enough, in my opinion, to be causing the wetness that is there. I have gaskets and washers etc to change the rocker cover gaskets, but my question is, whether or not there is/are any other known spots like the rocker covers that are likely to be the cause of the oil leak.
I intend to power wash the engine in the hope that I can identify where the leak is but all suggestions of where too take particular notice of more than welcome.
Declan
Post #376239 7th Mar 2016 7:47pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Check the oil breather pipes at the top of the engine at the back under the cover - they start to break down and need replaced from time to time. Plenty on here about checking and replacing them. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #376262 7th Mar 2016 11:05pm
Declan303
Thumbs Up will do
Post #376329 8th Mar 2016 1:32pm
holidaychicken
I wouldn't power wash the engine, I have heard bad things about doing it and causing all sorts of electrical problems
Post #376425 8th Mar 2016 7:51pm
Jet washed my engine on a regular basis with no covering anything up, waded on even more occasions.... never had an issue, alternator is sealed, no dizzy cap.... all sensitive elec bits are in a sealed box...what's left to not like a bit of water?? Pete
Post #376449 8th Mar 2016 10:05pm
Dolphinboy
Pete, how about the ABS unit Whistle
Smile Thumbs Up
Post #376531 9th Mar 2016 1:09pm
holidaychicken
well you carry on as it works for you, but as i said i have heard of people having issues, you have a loom going to all the injectors and just about everything has a sensor and not an electrical issue but there are quite a few hoses and vacuum pipes around the rear of the engine that are fragile on the 4.4 v8 which lead straight into the cam covers and sump which probably wouldn't appreciate high pressure water blasted into them to mix with your engine oil.
All i said was i wouldn't do it, i dont think its against the law, just the vehicles are fussy enough when it comes to electrics and being riddled with ECU's.
Post #376567 9th Mar 2016 5:44pm
Declan303
Had another look today and the driver side of the engine is wet-ish pretty much all the way up so I think it is the rocker cover that is causing the issue. I took a more gentle approach and sprayed that side of the engine with one of those degreasers and then washed off with the garden hose. Biggest problem is access to spray it and trying to see enough afterwards, pretty short on space down there Rolling Eyes
Post #376572 9th Mar 2016 6:07pm
holidaychicken
Cam covers are a very common fail as are the PCV valve pipes shown in the photos, this is when i was having a 'tinker' with my transmission. I changed mine a while back and there are a few instructional write ups on here and BMW forums and also the beisan systems site has some info as the cam covers are removed when the vanos repair is carried out.
The images show some of the PCV valve pipes that turn to mush over time and leak oil all over the back of the engine
Post #376576 9th Mar 2016 6:27pm
Declan303
Cheers,
Will definitely have a look at these when doing the cam covers. I do assume that you do not have to take the transmission out to get at them Smile Smile Smile
Declan
Post #376577 9th Mar 2016 6:32pm
Smile Thumbs Up
Pretty sure the problem people have had with that is down to condensation or something similar...
The first 1/2 dozen times I washed it I blew the surplus water off with an air line, then opened the plug and it was bone dry inside.. maybe some have failed seals or something but I never found water in mine after washing or wading....
Gone through just about every other plug under there and found no water ingress into anything... There are no exposed breathers that would allow water into the oil, if jetwashing damages a pipe then the pipe needed changing anyway...
The only problem I have had with water was the starter that was on it when I got it, it failed a few months after deep wading, water got in it via the front bearing, it looked like a cheap recon starter with an unprotected bearing, the quality refurbished replacement had a sealed bearing and has been fine since....
I'm not doubting people have had trouble with water under the bonnet but that could be because they don't dry it off properly after washing, mine gets blown off with an air line then I leave the engine ticking over for at least 30 mins to get some heat into it... I hate working on dirty engines so wash it quiet a lot... it also helps to spot trouble early... and lets face it mine is usually covered in mud, not just the normal bit of road grime... Pete
Post #376579 9th Mar 2016 6:38pm
