Home > In Car Electronics (L322) > Bluetooth ulf update |
Brooksy Member Since: 18 Sep 2015 Location: Caister-on-sea Posts: 23 |
can anyone help ? The aerial that plugs into the bottom of the ulf module, where should the other end be connected to ? Mine just goes to a similar white connector and is not plugged into anything ! 😱 Wished I had never started trying to for this and just bought a parrot |
15th Jun 2016 5:28pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7794 |
One end goes onto the ULF, I used the end with the 90 degree bend in it, and the other end goes to the Bluetooth antenna, that you should have fitted to the 2 bolts on the frame above the sat nav unit..... 2011 Range Rover Vogue SE 4.4 TDV8
15th Jun 2016 5:46pm |
