Home > Technical (L322) > Steering Column replacement
Bluestu33
United Kingdom 2014 Range Rover Vogue SE SDV8 Loire Blue
Hi,
A couple of days a go, my key would not turn in the ignition, so I had the car towed to a garage and they have just told me that the solenoid has failed and that I need a new steering column, which would cost about £3.5K. The key will not turn, and there is no clicking noise from the car, however, the radio and lights will work.
They have said that another temporary option is to drill a 2mm hole and squirt it with WD40 when it happens again, so for the time being I have gone with this and will collect the car tomorrow.
Is it work looking at a reconditioned steering column, or should I bite the bullet and spend £3.5K.
Thanks in advance!
Post #375568 3rd Mar 2016 4:50pm
the ignition is on the dash ,whats that to do with the steering column.. ... - .- -.
Post #375569 3rd Mar 2016 5:00pm
Well that's weird, didn't think that problem happened to a late one, recognised problem on the BMW FF's. I read that it was sorted when they facelifted...
Hopefully someone who knows the later ones better will comment soon.... Pete
Post #375570 3rd Mar 2016 5:03pm
Bluestu33
Stan - They just told me it was the locking solenoid that was failing and they cannot be replaced, so it has to be the whole steering column.
Post #375572 3rd Mar 2016 5:07pm
duckworthparts
Site Sponsor
failed ignition switch would seem the likely issue wouldnt it? You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #375575 3rd Mar 2016 5:18pm
Bluestu33
I will be speaking to the garage in more detail tomorrow, but they have said it is a module within the steering column that is causing the issue and only the whole steering column replacement can fix it.
£3.5k plus 2 hours labour.
I will ask them about why not the ignition switch tomorrow.
Thanks
Post #375579 3rd Mar 2016 5:35pm
It's the steering lock solenoid that get's stuck on the early cars, it runs out of lube, dries up and stops moving, the 2mm hole is a bodge to get it working for a limited time, if the hole is drilled slightly wrong then it will damage the lock.
I thought the later cars, after the 2006 face lift where they moved the key to the dash didn't have a steering lock or it was a totally different setup...
If it is as just mentioned then it is a fairly easy job to remove the column drill out the rivets that hold it together, and fix the issue within, a new one isn't necessary....
AFAIK Craig has sorted this problem for people in the past so it could be worth a trip over there for £3,500... Pete
Post #375585 3rd Mar 2016 6:08pm
Bluestu33
Brilliant thanks, I will contact Craig tomorrow
Post #375588 3rd Mar 2016 6:25pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Hallo, the columns with the defect solenoid are inside until May 2009, had here a RR TDV8 from 2008 from switzerland (was transported on a trailer, because fuse 18 trick and dangerous hole for WD40 was limited time), build out the column, new solenoid fitted, new electronic fitted, client payment was 1.300 Euro, and was happy to drive back one day later on his own wheels..., best wishes, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #375619 3rd Mar 2016 8:41pm
Bluestu33
I will be in Düsseldorf for 3 days in April, I'm quite tempted to drive over???
Post #375628 3rd Mar 2016 9:14pm
Meerbusch
You are welcome, sir....., please send PM to me, will answer of course. L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #375639 3rd Mar 2016 11:04pm
rar110
I was lucky enough to pick up a near new column as a spare from a 2009 MY10 L322. Is this different to the column in a MY08 L322? Will it fit? Sorry if it's a high jack. ______________________________
Post #375651 4th Mar 2016 6:09am
Meerbusch
The Mod.10 are cheaper of course, because they have no mistakes, because new construction, look at the part number, and look in Google Pictures, you will see the difference L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #375652 4th Mar 2016 6:37am
rar110
And does the MY10 column fit? ______________________________
Post #375657 4th Mar 2016 7:09am
miggit
Shocked How does the steering column lock stop the key from turning in the ignition, when it is only linked by wires? does not compute Shocked
When I put my key in the barrel the first thing that happens is the steering lock disengages as the transducer chip is read by the ignition switch, this is before any key turning has been done.... so unless there is a second solenoid on the key that is activated by the steering solenoid disengaging, there is no way that the column can have any effect over the key turning, as there is no physical link. If there is a second solenoid on the key, can it not be removed? as long as the steering is moving freely then I can't see there being any problem... Yesterday I couldn't spell Engineer... Today I are one!
Post #375658 4th Mar 2016 7:35am
