![]() | Home > Maintenance & Mods (L322) > Shorter front number plate |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35515 ![]() ![]() |
obviously legally it has to be the regular size but some have put a smaller one on,
Berty Member Since: 04 Jan 2016 Location: Leeds Posts: 73 ![]() ![]() ![]() |
The standard size number plate is not a legal requirement it's just the spacing and gaps that are, so in my case 4 digits I can legally go to a much shorter plate, thanks for the pic |
belldarr Member Since: 14 Jun 2014 Location: Bucks Posts: 149 ![]() ![]() ![]() |
Hi Berty, I have a smaller plate (5 digits) and had the same problem and it did look a bit rubbish. I then spotted on ebay a number plate plinth from ebay usa for their Range Rover sport variant as they have smaller plates. Hope you can see it on this pic.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Unnecessary quote removed
Yes I was thinking the same thing about losing the plinth may look a bit bland, also which border (if any) and I'm looking at 3D resin plates and can't decide if there to much or will look good,just wish I could have black and silver ones but that's far from legal unless I move to Guernsey, I want to keep the plates legal, but retain a classy look as opposed to the boy racer look if that makes sense decisions decisions |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2670 ![]() ![]() ![]() |
Have a wee muck about here,not bought any yet , still thinking about it:
Robgosty Member Since: 20 Dec 2013 Location: Manchester Posts: 232 ![]() ![]() ![]() |
Fancy platemaker
362bkr Member Since: 15 Oct 2014 Location: Devon Posts: 680 ![]() ![]() ![]() |
love this site ![]() |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
IMHO, short plates look the dogs on the front. Back, less so.
Where did you get the surround from ? It looks well that think I'll proceed and have the standard surround taken off and the holes filled up |
If you zoom right in, you may be able to see that I took off the original mount, cut out a section from the middle and then fixed the 2 pieces back together. As the plastic is soft, they blend very well, only showing a faint joint line hidden by the plate itself.
