Home > Technical (L322) > Adaptive headlights. Moving not sure.
Cavalier
2011 Range Rover Vogue 4.4 V8 Orkney Grey
I had a 2006 Discovery with adaptive headlights, you could really see the light beams moving about in line with the steering wheel. Now I have a 2011 fullfat it has adaptive headlights, they are shown on the build sheet and also has the warning light in the bottom left hand side of the dash display, it lights up and goes straight out, as it should if there is no problem found with the adaptive lights.
The trouble is I can't see the beams move when I turn the steering wheel, or is it more subtle on the later vehicles?
I used to notice that the beams on my old car moved when I went round a tight round about.
Does anyone think their adaptive lights are a bit naff?
Post #371196 8th Feb 2016 12:02am
I have the same model as yours and my adaptive lights are ace! A quick thing for you to check would be to make sure the leavers are not set to european use? If they are, that will give you a flat line beam and obviously you will see less movement without the triangle type beam pattern set for use on UK roads... Thumbs Up
Post #371200 8th Feb 2016 12:53am
Cavalier
Thanks for the reply Craig, could to tell me where the levers are.
Post #371221 8th Feb 2016 10:05am
Search button in the middle of the top bar of page sir Whistle Whistle Whistle
Thats how i found this Whistle http://www.fullfatrr.com/forum/topic810.ht...p+european
Post #371225 8th Feb 2016 10:29am
http://www.fullfatrr.com/forum/topic2863.h...ing+europe
Post #371226 8th Feb 2016 10:30am
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
I had a 2011 with adaptive lights. Driving in a straight line on a pitch black night, one could wiggle the wheel a little and see them turn with the wheel.
Post #371228 8th Feb 2016 10:45am
Cavalier
ha ha thought about the search as soon as I replied to your post, sure enough found the answer Thumbs Up
Post #371230 8th Feb 2016 11:06am
