Home > Technical (L322) > odd one - 2006 TD6
5c0tty
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
odd one - 2006 TD6
Hi Guys
Driving down the motorway yesterday my car had a bit of a fit, first of all i had air suspension fault 30 mph max and the little LED on the controls went off. i slowed down as much as i could but the car seemed fine, then all of a sudden it cleared and everything was fine!
about 30 mins later, 'bong' suspension fault in the display, nothing about max speed. I looked at the 4x4 display and the front right wheel looked liked it had dropped off! it was way down off the screen. So i pulled over turned off and on and all was happy again and got to my meeting.
On the way home, bong and the same message as before, air suspension fault 30mph, but cleared about 2 mins later. It did this 2 or 3 times more.
As i was pulling off the motorway, i then got trans fail mode, Sad pulled over and it cleared fine.
any ideas or is my car just falling apart
many thanks guys
scotty
Post #370233 3rd Feb 2016 9:51am
Cold failing battery syndrome sounds likely...
Always the first low voltage warning will be EAS inactive issues... Second usually is Trans Failsafe...
Check the alternator output and the condition of your battery sir... Battery only needs to be 99.9% perfect before these issues start happening...
Post #370237 3rd Feb 2016 10:05am
Mr Tee
Wise words from Craig. So many electronic systems in these things, they throw a spaz if not getting the right amount of juice!
Craig, are you on a tea break??
Post #370238 3rd Feb 2016 10:09am
No no, sat in a car doing an update... Whilst waiting i often flick onto the forum Mr Tee Thumbs Up
Post #370241 3rd Feb 2016 10:25am
i've just rang Lorna to get you a cup of tea Craig... Thumbs Up ... - .- -.
Post #370249 3rd Feb 2016 11:03am
Bofa Bill
Scotland 2003 Range Rover SE Td6 Epsom Green
Scotty haiv a look at my post in this section, voltage.
What your describing was how my probs started.
And cups of tea never helped Big Cry Made in Scotland frae 'Girders'
Post #370442 3rd Feb 2016 11:21pm
