Home > Technical (L322) > Any one changed pixel ribbon???
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
As most RR owners suffer from the dash pixel problem. Bought a ribbon for £24. Anyone fitted and will it end in disaster??
Post #36765 18th Nov 2010 7:51pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
No... but you have my interest. Photos as you go please!
Not had the bottle to do it yet.
Cheapest I've seen the ribbon was £50 as well but not looked for a while.. still licking my wounds from todays automotive hit. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #36766 18th Nov 2010 8:04pm
Nickj
Will do. AKspeedo.com and £24 notes inc delivery. Only had a couple in stock when i spoke to them though.
Post #36771 18th Nov 2010 8:22pm
oodathort
the trick is not to damage the connector where the ribbon is crimped as this is where your problem manifests lots of time you can undo this connection remake it and hey presto problem solved
Post #36773 18th Nov 2010 8:29pm
Nickj
If the ribbon is crimped, how do you remove safely and replace effectively? Is it hard work getting dash pod out and striping to required level?
Post #36774 18th Nov 2010 8:33pm
oodathort
removing the cluster is straight forward you have to be careful in dismantaling the cluster you will need to drill some plastic rivet heads out use an electric screw driver with a drill bit not a power drill when removing the ribbon use a hair dryer to warm it up to aid removal
Post #36775 18th Nov 2010 8:41pm
Nickj
thanks for the tips. Not going to rush into doing this job if honest until sorted out other little probs.
Post #36777 18th Nov 2010 8:50pm
davemfox
Me too Thumbs Up
Dave 1993 YZF 750 SP
Post #36807 19th Nov 2010 8:40am
dan_uk_1984
Hmmm, it's £90 for someone else to do it. I usually advocate doing things myself, but in this instance I think I would rather someone else took the risk.
http://cgi.ebay.co.uk/BMW-E38-E39-X5-Instr...230b896452
Post #36808 19th Nov 2010 8:44am
SteveMFr
Site Sponsor
Did you remove the needles or drill holes to access the screws? This was the very worst part of the job, as far as I'm concerned.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #36839 19th Nov 2010 1:58pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Think ill go this way when i'm ready to lose driving the car for few days.
With the cluster out of the car for a few days i would like to keep the battery connected for the alarm, will this throw a fault? 2004 black Vogue TD6
Post #36860 19th Nov 2010 3:28pm
letsavit2
Another thing... Whistle
My mileage is sometime hard to read, is this a MOT fail? 2004 black Vogue TD6
Post #37213 20th Nov 2010 6:31pm
This should help you Thumbs Up
Post #37216 20th Nov 2010 7:04pm
letsavit2
yea have read that guide or similar.
Exactly why ill get someone else to do it, fiddley jobs like that usually involve me losing my temper and the whole lot smashed up... Laughing 2004 black Vogue TD6
Post #37217 20th Nov 2010 7:09pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I've just got in my car today, and the dashboard pixels have fixed themselves!!
(Now to see if the HDC inactive does the same..........)
Post #45145 8th Jan 2011 12:43pm
