Home > Technical (L322) > TDV8 Coolant Temps
Road Stone
Australia 2007 Range Rover Vogue SE TDV8 Java Black
TDV8 Coolant Temps
Hi Folks,
Can someone advise what should the "normal" coolant temp be in usual driving conditions for the 3.6TDV8?
IE Round town/Hi Way etc.
Many thanks
Jerry
Post #366837 13th Jan 2016 12:55pm
that info should be in the WM.. ... - .- -.
Post #366858 13th Jan 2016 3:11pm
Road Stone
Thanks.
But wanted peoples experiences, Motorway/round town and stuck in the jam crawling through traffic.
Does anybody record their figures?
Cheers, Jerry
Post #367216 15th Jan 2016 2:21pm
Mine just sits in the middle all the time, once it's warned up Got - 2017 SDV8 Autobiography in Loire Blue
Post #367217 15th Jan 2016 2:30pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Just happened to check ours after a run before work on Wednesday with the IID tool.
Water temp was 85 deg, with the temp gauge sat in the middle.
Apparently with the temp gauge, once the engine gets up to around 80 deg and as far as 105 deg, it will show normal.
Before and after these ranges that's when it will show it either warming up or going into the hot zone.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #367284 16th Jan 2016 12:19am
Road Stone
Thank you,
Yes mine is around 86 whilst driving. In the traffic jam (and they are serious ones here), it climbs to 90.
I'm at an altitude of 3500-4000 feet, and the external temp was 29c on the day I took those.
Cheers, Jerry
Post #367293 16th Jan 2016 5:44am
