Home > Technical (L322) > 4.4 engine won't start any ideas from this video clip |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Sounds like a fuel issue to me . As you say it nearly wants to go ...
24th Dec 2015 2:49pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
Does sound like a fueling issue rather than anything else as it's almost catching to run but not quite. Try some Easy Start or similar volatile spray in the intake.
24th Dec 2015 3:15pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
Matt
24th Dec 2015 3:18pm |
espaceboy Member Since: 02 Aug 2014 Location: Fae Fife Posts: 86 |
some tips in this thread
24th Dec 2015 4:23pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
Cheers Dave, will give that a try tomorrow! Matt Current 2012 Range Rover 5.0L SC Ultimate Edition 2012 Range Rover 4.4L TDV8 Autobiography 2010 Range Rover 3.6L TDV8 Autobiography 2003 Range Rover 4.4L V8 Bespoke Vehicle Inventor of the retro fit paddle shift and many other modifications. Creator of the custom 2010+ RR MK4 splash screen. Creator of the Range Rover CarPC and lots more! Founder of Range Rover Owner rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos ➞ YouTube.com/RangeRoverOwner |
24th Dec 2015 9:02pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
If you have done the fuel pump, try finding the fuel pump relay in the boot area fuse box, and try switching it with another. In same fuse box etc.
26th Dec 2015 1:10pm |
Gone out today, put the battery charger on as it was low because of all the trying to start it. Came back an hour later and just thought I would give it a go, engine started first time. Was a little lumpy at first but after about 10-15 seconds was purring away as normal no problems at all. Has started each time I have tried it now. No idea what could have caused it, my only inclination was maybe water in the fuel as the tesco I got the fuel from was closed the day before I filled up as they found water in the petrol tanks.
26th Dec 2015 2:37pm |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 |
If so, time for a full dose of redex to flush out the tank before filling with ultimate high octane Current vehicles
26th Dec 2015 2:51pm |
HI Matt
26th Dec 2015 7:24pm |
Tut tut, Tescos have been bulking up their chicken and ham for years with water. No wonder they give 5p a litre off!
26th Dec 2015 10:38pm |
