Home > Technical (L322) > Locked out please help if you can.
SteveyD
England 2003 Range Rover Vogue Td6 Bonatti Grey
Afternoon all. Well this month the FF has had a fair bit spent on it in the form of discs and pads all round (supercharged front calipers) and brake lines throughout, due to corrosion I replaced them all. And now I'm repaid by being locked out.
ANY help would be gratefully received.
So far:
Fob will not unlock the doors, alarm is still engaged as the led flashes to say so. Also ECU is recognising the fob because when I press the button the led alongside 'P' illuminates as the ECU awakens.
Perhaps the battery has gone flat? It's a 12 month old bosh with new alternator so I can't see it, currently I've got the belly pan removed and a trickle charger hooked up to the alternator + and chasis for ground. 4 hours of charging has made no difference.
Ideally of course I'd unlock the car with the key, but of course the lock just turns and has done since I bought the car 3 years ago so naturally that's my own fault.
Im about to replace the trickle charger with jump leads to my other car and see if that helps but I'm not so sure it's a battery issue?
I'm being deadly serious here, which window would be best to smash? The doors are obviously deadlocked so can't be opened with a slider or hook, I'm guessing a rear window would be the best option.
My car will be for sale next week, I'm done!
Stevey
Post #359191 27th Nov 2015 1:53pm
robbo770
Scotland 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Try a metal coat hook and press the centre dash unlock button
Failing that the easy open boot lid to avoid any breaking of glass Thumbs Up Current vehicles
4.2 SC FFRR RSE 2010- facelift
Range Rover Evogue Dynamic Lux
Gone
Rejected RRS my14.5 nightmare
Disco B4 XXV convert
Freelander 06 SE
06 RFFRR 4.2 SC Vogue RSE
Audi A8 4.2Tdi Quattro (hated with a vengence!!)
54 FFRR 2005 model V8 4.4 Cobra Variant
53 Mitsubishi Shogun V6
Post #359195 27th Nov 2015 2:03pm
The best window to smash is whichever one your local glass place can source the quickest Whistle
Sorry that I can't offer any more constructive help than that Embarassed
Post #359196 27th Nov 2015 2:04pm
key in door lock?
edit read your post again Embarassed ... - .- -.
Post #359197 27th Nov 2015 2:05pm
SteveyD
Thanks for the reply, ive read that the central unlock button won't work due to the alarm being engaged. You say easy open the tailgate? I'd thought about undoing the lock mechanism and trying to force it...
Post #359198 27th Nov 2015 2:05pm
PM the people on this thread
Post #359199 27th Nov 2015 2:06pm
SteveyD
Door lock just turns round and round and round Stan. A bit like my head right now!
Post #359200 27th Nov 2015 2:06pm
trickle charge via tow electrics or side indicator... ... - .- -.
Post #359201 27th Nov 2015 2:09pm
SteveyD
Face lifted Stan and tow electrics are only for a trailer. Lol did you read all of my post? Razz
Post #359203 27th Nov 2015 2:13pm
tired from staying up last night for the black friday deals, sorry steve hope you sort it.. ... - .- -.
Post #359205 27th Nov 2015 2:15pm
SteveyD
Haha do you have enough change left over to buy my face lift parts? Rolling with laughter
Cheers Thumbs Up
Post #359206 27th Nov 2015 2:34pm
robbo770
The boot lid is fitted with emergency release tabs, they are a Censored to get to but better than braking glass, at least get you in the car Thumbs Up
Search it on the forum I remember it somewhere Exclamation Mr. Green Current vehicles
Gone
Freelander 06 SE
Post #359213 27th Nov 2015 3:22pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
@SteveyD
You have a PM
Good luck Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #359216 27th Nov 2015 3:25pm
SteveyD
Thanks all who have replied, after spending the afternoon doing other things I thought I'd try again. Still no joy, held the buttons down for an eternity. Nothing. Ranted and cursed (lots). Nothing. Then as if by magic, the tailgate button worked!
I climbed through to the front with all four doors still locked and can confirm that the window switches, door handles and central locking button would not open the doors. Putting the key in the ignition and turning the ignition on caused the drivers side indicator to flash a few times with two alarm beeps. I started the car and attempted the central locking button, all doors unlocked.
That's as far as I'm going tonight. I'll play about tomorrow.
Note to self.... Repair key lock ASAP, I'd planned to delete it completely.
Again, thank you to everyone who has helped so far. I'm very grateful.
Post #359236 27th Nov 2015 6:02pm
Thumbs Up ... - .- -.
Post #359240 27th Nov 2015 7:05pm
