Home > Wheels & Tyres > Can I legallyfit lower speed rated winter tyres to my 4.2SC? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35278 |
technically replacement tyres must be rated to OE spec or above......say that lots do fit lower speed rated but i would be careful with the load ratings.. ... - .- -.
5th Nov 2015 9:37am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Obviously you would need to cover your arse and tell your insurers but if it was illegal how could manufacturers like Porsche offer winter tyre programs with lower speed ratings ? 2008 MY Supercharged
5th Nov 2015 9:52am |
xjsracer44 Member Since: 29 Nov 2010 Location: Hertfordshire Posts: 274 |
Thanks Stan, that's what I thought.
5th Nov 2015 10:08am |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1511 |
Definitely worth ringing the insurer, however V rated should be 150mph, my S/C is limited to 130mph anyhow.
5th Nov 2015 11:17am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
I guess it depends on whether the car is spec'd to need Y rated tyres, or whether it just happens to be fitted with them as that's what the manufacturer had available at the time.
5th Nov 2015 11:24am |
Interestingly when I type my registration in here I get different speed & load ratings for different diameter wheels......
5th Nov 2015 11:27am |
the speed rating isnt just about the top speed the tyre is capable of but it also takes into account the 'forces' the tyre suffers getting to that speed..
5th Nov 2015 11:36am |
All good points, thanks guys.
5th Nov 2015 12:29pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1374 |
Your dealer should be able to supply a topix list of LR homologated tyres. I tried to find the 322 list through google but found only the 405 list. It has several 255/55R20 V rated winter tyres. I'd say if LR have homologated the tyre it must be legal, though I'd still tell the insurers.
5th Nov 2015 3:53pm |
I checked mine & they are V rated
5th Nov 2015 4:01pm |
Thanks Alistair, I checked the first site & it also gave me varying speed ratings, including the H rated Continental winter tyre, but has a disclaimer saying that fitting lower speed rated tyres can invalidate your insurance.
6th Nov 2015 8:28am |
Just means Conti don't make one - plenty of other 255/50/20 109V Winters available Hard to imagine how a V rated tyre would be OK for an L405 5.0SC and not OK for a 4.2SC. |
6th Nov 2015 5:20pm |
Edfors Member Since: 26 Oct 2012 Location: Uppsala Posts: 168 |
Here in Sweden the law require a winter tyre to be fitted and it also states that the winter tyres can have a lower than the specified speed rating.
http://www.theaa.com/motoring_advice/safet...he-uk.html But then they continue and say you better check with your insurer as well. Supporter and maintainer of EDF - Mrs Edfors' shopping cart. |
6th Nov 2015 6:04pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
A quick check online suggests the top speed of the 4.2 is governed to 130mph. It's construction and use regs which specify that tyres should be rated no less than the max speed of the car, so with that in mind, then H rated tyres at 130mph should in theory meet that regulation. It's also the principle I'm working to when looking for winter tyres at the moment. There are a lot more H rated tyres to choose from. Regarding telling insurance, there is a list that shows which insurers ate generally ok with changing to winter tyres and whether they need told or not. A number of years ago, I added a comment to my policy saying I fitted different tyres at different times of the year, but that the tyres met the load and max speed of the car. They had no issue with it.
7th Nov 2015 8:35am |
