Home > Wheels & Tyres > Front Tyre Wear 2012 Westminster TDV8. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
My Vreds always wore badly on the front outer edges - about an inch into the tread.
29th Oct 2015 9:18pm |
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 186 |
Thanks, that's exactly what mine are doing.
29th Oct 2015 9:26pm |
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 |
I think you hit the nail on the head, assuming your front suspension geometry is OK. You should also consider that these heavy machines can corner quite well, but the higher the speed, the greater the tyre scrub, so driving style could/will also contribute. Regards Royston 2008 4.2 Supercharged Autobiography 1994 Classic Vogue SE 1999 Rover BRM 1987 Rover Vitesse Twin Plenum |
29th Oct 2015 9:35pm |
Er, yes. I figured that my driving style was a potential contributor.
29th Oct 2015 9:42pm |
High speed cornering on bends would be the root cause................... Regards
29th Oct 2015 9:50pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1751 |
I have 20" Scorpion winters, and they are wearing exactly the same... |
29th Oct 2015 10:07pm |
Conclusion; Eighty quid saved but need to slow down on corners!
29th Oct 2015 10:23pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Braking on the turn will do it, I know this after wearing out some expensive BF Goodrich tyres that way.
29th Oct 2015 10:35pm |
That's one thing I don't do. Destabilising a heavy car mid-corner is a scary thing.
29th Oct 2015 10:40pm |
My driving style could also be called 'enthusiastic' but I also try not to change speed through bends.
30th Oct 2015 8:33am |
I'm going to try 255/55/20 tyres next time.
30th Oct 2015 10:04am |
Swap them side to side before moving them to the rear.
30th Oct 2015 1:34pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35278 |
most FF tyres are asymmetrical Will, ie they will have the word 'outside ' written on the side wall... ... - .- -.
30th Oct 2015 2:04pm |
Stanley have you mislaid your specs today
FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's Mantec Sump Guard, Rigid Load liner, MY10 BT upgrade. |
30th Oct 2015 2:36pm |
